Crankshaft Position Sensor Problems... Please Help!
Old Aug 10, 2010
vcantrell's Avatar
vcantrell is an unknown quantity at this point
Hey guys. quick background on my 05' 1.7l SOHC vtec 7th gen civic....
I blew a headgasket and had that fixed. the valve cover gasket was screwed when they fixed the head gasket and I was pouring oil over the engine for a couple weeks. Well, it's fixed now but the battery died or went bad so I replaced it. Drove it from tennessee to michigan it drove great. Next morning it turned over way too long before starting.
After that I drove it a mile and it was having trouble shifting... it would jerk like the transmission was struggling and the check engine light was on. I pulled over and shut it off. I immediately turned it back on and it ran perfectly. the check engine light was for the crankshaft position sensor. Two errors: One said a malfunction of the sensor, the other said "intermittent".
I drove it back down to tennessee just fine. EVERY time it sits for a few hours, I have to drive it for like a minute and shut it off and turn it back on before it will work perfectly.
I don't know much about these things but is it possible a fuse is blown or a battery is dead that is keeping the CPS's memory of the car? and every time it sits it goes dead and has to relearn by me driving it for a mile?
Please help me...
thanks
Old Aug 15, 2010
vcantrell's Avatar
Re: Crankshaft Position Sensor Problems... Please Help!
recently, it's been giving me further problems. It died the other day... while I was driving it. A lot of idling and slow driving (probably 15 minutes worth) and the electrical system just started dying. radio went off, then air, then the instrument panel started freaking out. Like the battery went dead or the alternator stopped working. After I started driving fast I got the power back and I haven't had that problem since. It's weird...
Also, I stalled it out again. It's been drinking gas like crazy. ANY ideas?
Old Aug 15, 2010
grendel's Avatar
grendel has a spectacular aura aboutgrendel has a spectacular aura about
You've double-posted.
Only one thread is necessary.
Please pick one, and stick to it
Old Aug 15, 2010
vcantrell's Avatar
:-O Thanks for the advice ^^ you have helped me tons. Much appreciated xD
by the way... so did you
Old Aug 16, 2010
grendel's Avatar
Indeed.
Had to make sure you got the message.
Didn't know which thread you'd settle on.
Still both, apparently.
Old Aug 18, 2010
civicbyrc's Avatar
civicbyrc is an unknown quantity at this point
Get a battery electrical system check. Sound like your alt is taking a crap. Tap on the crank position sensor with the back of a screw diver and wiggle the wire harness while running and see if it messes up how the car runs.
BootyDo
Jun 21, 2016 03:45 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Jul 12, 2015 11:54 AM
aultman1990
Jul 9, 2015 08:27 PM
ZILLA
Jul 5, 2015 05:24 PM
