interior door panel repair
Old Jul 26, 2010
civicbyrc's Avatar
civicbyrc is an unknown quantity at this point
So this summer I'm going to try and fix the interior panels in my wife's civic sedan. The fabric part of the panels has become undone from the door. My question is, should I take the panels off completly and disassemble them to reattach the fabric with some 3m spray adhesive or can I glue the fabric on with the panel attached with some cement glue? Did a search and couldn't find anything related to this.
Old Jul 26, 2010
lowlife9's Avatar
Re: interior door panel repair
i believe that the panal is one molded piece so just keep it on thats what most people do buy it would make it easier if you remove it here is a DIY.
http://www.***********.com/forum/showthread.php?t=6500
sorry looks like they block other honda forums.
Old Jul 26, 2010
7thgenhonda.com/forum/showthread.php?t=6500
Old Jul 27, 2010
Psykotik_913's Avatar
Psykotik_913 is an unknown quantity at this point
Thumbs up Re: interior door panel repair
I recently had to do the same thing in my '05 coupe. 3M spray adhesive is what the dealership techs recommended to me (you can get it at autozone, etc) the advantage of taking it OUT of the car is just more maneuverability and not getting pissed when you're hunched over sitting on concrete... I can give you a play by play on what to do too.
Tools:
*Adhesive remover
*Bondo spreaders (for smoothing and tucking)
*Mild sand paper
*3M spray adhesive
*Surface cleaner
Size:  4.3 KBName:  BondoSpreaders2.jpg
Size:  4.5 KBName:  sprayadhesive2.jpg
1) Remove as much fabric as you need/want from the area i.e. redoing ALL of it, or just the part that's loose. Just remember the placement of the fabric , even small tweaks can make folds and stuff.
2)Use the adhesive remover to get rid of all the old crap that's on there.
3)Grab a little bit of sandpaper and scuff the area- don't get carried away, its just b/c glues stick to rough surfaces better than smooth slick ones.
4)Use the Total Prep cleaner to clean the surface. LET IT DRY FOR A WHILE! Otherwise the chemicals in the cleaner can mess up your adhesive.
5)I just used some masking tape and old newspaper to mask off the area, then use the adhesive spray-light coats only, otherwise you'll have knots of crap under your fabric.
6)Let the adhesive get tacky i.e. it leaves strings when you lay & pull the fabric up.
7)Lay the fabric back over the area and GENTLY start smoothing it (center->out) towards the edges. If you press too hard, then the adhesive is most likely going to bunch up, or get pushed through the backing on the fabric.
8)Then just use the spreader to push the ends of the fabric into the channels around the area. (If not using plastic spreader, be cautious of cutting into the panel)
After all of this i just put the panels back in and there weren't any worries.. You might leave them out though, or follow the drying directions on the adhesive can.. Hope this helps!
Old Jul 28, 2010
civicbyrc's Avatar
Thanks Psykotik_913 that was very helpful. A bondo spreader didn't even cross my mind, that would be handy to tuck it into the seams.
Old Jul 31, 2010
np
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MamaBear2015
May 18, 2015 07:37 PM
timpan
May 18, 2015 07:06 AM
MamaBear2015
May 3, 2015 02:17 PM
supercivic01
South
Nov 30, 2001 11:27 AM
