is it tranny or clutch?? HELP!!!
Old Jan 22, 2010
SuperMike's Avatar
SuperMike is an unknown quantity at this point
hey guys,
well this morning while i was taking my brother to school, i noticed that it was hard to put my car into 3rd and 4th gear. but 1st 2nd and 5th went in smooth. it just start happening this morning. yesterday it was fine. so i want to know is it because of the tranny or the clutch?
PLEASE HELP!!
Old Jan 23, 2010
dspeedcrazy02's Avatar
dspeedcrazy02 is an unknown quantity at this point
Re: is it tranny or clutch?? HELP!!!
i had a similar problem and found out that it was the tranny fluide,it was to low,you might check by checking the level in the tranny.
Old Jan 24, 2010
sk8nbmxr411's Avatar
sk8nbmxr411 is an unknown quantity at this point
Change your transmission oil. I went to the dealer and got the oil that goes in the s2000 tranny. It works so well!
Old Jan 25, 2010
SuperMike's Avatar
ok thanks guys...thanks a lot.
Old Jan 26, 2010
king.0c's Avatar
king.0c is an unknown quantity at this point
if changing your transmission fluid only helps a little bit you should change your shifter cable bushings. Get them from strutking.com. The improve your shifting the most in my opinion.
Old Jan 29, 2010
SuperMike's Avatar
well hey guys i stumbled upon another problem...im DIY on my tranny fluid and where do i pour in the new fluid...i had some friends that said it was easy but they own 92-95 and 99-00 so mines totally different. so i want to know where i pour the fluid in...
Old Feb 5, 2010
try the reverse light sensor,thats what i use. under the intake an the top side of the tranny.
Old Feb 5, 2010
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Yep.. by far the easiest point to add tranny fluid. Be sure you add exactly the right amount though. Transmissions get unhappy when you either over or under fill them. Also trans fluid is one of the few things that you really do need genuine Honda fluid. They put some special silica and other additives that even royal purple or redline don't use that the honda transmissions need.
Old Feb 8, 2010
04 Honda Civic's Avatar
I never put gear oil in a manual on a Honda, but I have done it on my Sentra, isnt it impossible to overfill the fluid, as once it starts to come out of the hole its full?
Old Feb 9, 2010
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
It is impossible to overfill if you use the correct fill point. The suggestion is that it is easier to fill from the reverse light sensor which is at a higher location than the normal fill point. The best solution might be to go ahead and remove the fill plug and fill from the reverse switch location until fluid comes out the normal fill hole.
I have never run into it but I have heard it is best to always loosen the fill plug before removing the drain plug on a transmission, differential, transfer case, etc. If you drain the fluid and then find you can't remove the fill plug you have a major problem.
Old Feb 9, 2010
ah I see what your saying, well hopefully that helps the OP too.
Old Feb 11, 2010
SuperMike's Avatar
thanks guys i just did the change the other day. you all been helpful.
velozp
Dec 13, 2015 11:28 AM
rayaan_wasty
Sep 14, 2015 02:00 PM
Klame9420
Sep 7, 2015 10:03 PM
tommycanada
Sep 5, 2015 04:59 PM
dantheman42
Sep 4, 2015 01:10 PM
