Handling Question
Old Nov 16, 2009
sk8nbmxr411's Avatar
sk8nbmxr411 is an unknown quantity at this point
Handling Question
I just bought a DC strut bar and Tein S-Tech lowering springs for my 05 coupe. So far my suspension is stock, other than 17'' rims, and I was just wondering how much of a difference I am going to feel once I install both of these. I'm not expecting it to be dramatically different I was just curious how much improvement I am going to feel. Next on the list is the sway bars! Thanks in advance for your input
Old Nov 16, 2009
Re: Handling Question
Oh and I also ordered a camber kit to align everything, so that will not be a problem.
Old Nov 16, 2009
lowlife9's Avatar
not much your on stock dampers so the springs are basically for looks and the strut bar doesn't really do anything for our cars i have a neuspeed and i barely felt a difference at all if any but your best bet is the sway bars they make a huge difference in handling.
Old Nov 16, 2009
turbo zombie's Avatar
turbo zombie is an unknown quantity at this point
a strut bar won't make it handle much better, but steering response and feel will be much tighter.
Old Nov 16, 2009
Keepitmovin's Avatar
Keepitmovin is an unknown quantity at this point
I dont know about improvement? With a 1.5-2" drop on 17's and stock shocks/struts - it's gonna get rough. You'll probably blow your shocks in a few months anyway so I'd install all at once. Look in the springs vs coilovers threads.
Old Nov 17, 2009
the springs lower the car 1.3''front and 1.4'' rear, I know the ride will be rough but I don't think it will blown my shocks that fast. With that drop do you still think I will?
Old Nov 17, 2009
Oh and Im playing on getting Progress 27mm front and 22mm rear sway bars. Do you think this suspension set up will be good. I was also looking at getting TANABE Front Under Brace and a Tein rear strut bar.
Old Nov 17, 2009
nice tires are the best thing to change to make your car handle better. super sticky tires on a stock car will handle better than a car with all the possible suspension mods, and crappy tires.
Old Nov 17, 2009
lowlife9's Avatar
i have heard of possible clearance problems with the rear progress bars and after market exhaust i would look into it unless your keeping the stock exhaust .you could also look into extended ball joints.
Old Nov 17, 2009
extended ball joints correct the change in bumpsteer from lowering, correct? i haven't seen anyone that makes them for our cars...
Old Nov 17, 2009
lowlife9's Avatar
yes you are correct there is a member on another site that has a set i believe from J's racing but they expensive about $350 each.
Old Nov 17, 2009
I have a DX with an axle-back. What sway bar kit would you recommend?
Old Nov 17, 2009
if you have a dx, you have no sway bar in the rear. need to get the dezod.com adapter kit to even be able to use a swaybar. its worth it tho, the rear bar makes the most difference.
Old Nov 17, 2009
lowlife9's Avatar
progress also has a adapter kit for the DX.
Old Nov 17, 2009
GreenMachineDX's Avatar
GreenMachineDX is an unknown quantity at this point
Anyone has a website that i can go and check the adapters for the dx..
Old Nov 17, 2009
um read my last post lol
Old Nov 18, 2009
lowlife9's Avatar
yea www.progressauto.com
Old Nov 18, 2009
dezod.com has the adapter. But my question is, will the progress one fit, even with the adapter if i have an axle back? I did a quick search and didn't find an answer. So does anyone have a DX with the progress rear sway kit without any clearance issues?
Old Nov 18, 2009
theres too many factors to know for sure. every exhaust sits slightly different and some might rattle against the bar. progress bar is thicker than stock and rsx, so its possible. you could always have the exhaust hangers adjusted tho.
Old Nov 18, 2009
So should I buy the kit and then IF i have a rubbing problem adjust the hangers?
Old Nov 18, 2009
yeah chances are nothing will rub. some people also wrap some thermotec heat wrap around the swaybar where it comes close to the exhaust.
Old Nov 18, 2009
is that the black mesh looking stuff i see people wrap their headers and exhaust with?
Old Nov 18, 2009
sortof yeah, sometimes its like brownish mummy bandage lol.
Old Nov 18, 2009
lowlife9's Avatar
thats actually a good idea for the section thats hitting my sub frame ill just wrap the hell out of that sectionand hope it doesn'tfall of the cheapest place was autozone i thenk 40 bucks were else can i get it for cheap and don'tsay ebay.
Old Nov 18, 2009
thermotec wrap, i know advance auto has some for much cheaper but theyre not in every state
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
glockma630
Aug 1, 2015 10:30 AM
ballmich
Jul 9, 2015 11:59 AM
