how many miles, what problems u had?
Old Oct 12, 2009
brian02's Avatar
brian02 is an unknown quantity at this point
How many miles on your civic?
What year is it?
Automatic or stick?
What kinds of problems have u had?
What have u done to it?
Thanks..
Old Oct 12, 2009
Re: how many miles, what problems u had?
90k miles
2002
auto (with defective secondary clutch pack carrier)
alternator, headgasket, slipping trans, LCA bushings, shocks, rust, o2 sensors, vtec solenoid, wiring issues, rattles, water leaks, rear main seal leaking (but fixed by itself, *lucky*) and some other normal problems from old age. im sure i forgot some.
I/H/E, denso iridium plugs, AEM PS pulley, ground wire upgrade, HVS-GT, better battery 500cca, lowering springs and better shocks, all ES poly bushings, alpine radio, infinity speakers, alpine amp, B&M trans cooler and HX CVT filter, passwordjdm.com magnetic oil drain plug (it works), aftermarket endlinks, strut bar, K&N oil filter with 5w30 valvoline maxlife oil, the rest are cosmetic and not performance related so wont post them.
Old Oct 12, 2009
lowlife9's Avatar
120,000 miles
2004 VP
automatic
im the second owner and i have had no major problems so far knock on wood only thing is the transmission is a little sketchy.ow and the rear left brake squeaks when i release the pedal .
I/H/E, denso iridium plugs,upper neuspeed strut bar,ground wire upgrade,bigger battery 800cca,full progress coilovers,poly bushings,ingals camber kit front and rear,VIS carbon fiber hood,magnetic drain plug,water pump,timeing belt and tensioner, transmission flush,royal purple oil and filter, jenson flipout,alpine amp,kenwood amp,tsunami grounds wires and capacitor ,mb quart highs and mids,powerbass 12s,
Old Oct 12, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Umm...
92K
2001 LX
5 -speed
Cooked an alternator on the dyno, replaced 2nd and 3rd gear sets along with reverse, crazy wiring issues, killed a set of fuel injectors, lots of rattles and squeaks traced down, 2 speakers have died (still dead), torn 3 motor mounts, 2 dead map sensors, 1 dead TPS, secondary o2 sensor dead from rich conditions under boost, popped a head gasket from boost, blown charge pipes off numerous times, both wheel bearings replaced, a couple wheel studs
Dezod turbo setup, y8 intake manifold, 3" exhaust, tokico blues and springs, ingalls stiffy, stainless clutch lines, battery relocated etc. etc. the list goes on, I'm just too lazy to list them all, but that's the gist of it.
Old Oct 12, 2009
craddmd's Avatar
craddmd is an unknown quantity at this point
2001 LX
Automatic
106,000 miles
Done:
-Replaced rear compliance bushings (rear suspension squeak)
-Replaced numerous wheel studs (swear I didn't cross-thread them)
-Replaced both front wheel bearings (one may have been from accident, other from dealer incompetence replacing front wheel stud)
-Replaced ELD
-Replaced throttle body after TPS went bad
Not Done:
-Front compliance bushings are shot
-Center console/shifter light out
-Driver's window doesn't auto-down (motor's also way too loud)
-Stupid center air vents start rotating upward when car interior gets hot
-Whatever the hell's causing my right rear suspension thump on rebound
Upgrades:
Not many - wheels in stock size and ATE front rotors with Akebono ceramic pads (all stock size)
Does have fewer rattles than my mom's 2008, though...
Old Oct 15, 2009
lexxie's Avatar
lexxie is an unknown quantity at this point
2002
361,902 to be exact
manual
alt my tranny slipping, blown headgasket driving back from northcarolina, now my throw out bearings going bad
Neuspeed lowering springs
Adjustable eccentrics for alignment
Neuspeed shift kit Gear shift shortened 2 1/2 inches
Front strut brace rear strut brace
ceramic free flow header
aem intake
More, but im lazzzzzzzzzzzzzzzzzzzzzzzy
EDIT: 362,001 original engine miles
Old Oct 15, 2009
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
2004
manual
74000 kms
third gear grinds at 4k + rpm
DC sports short throw shifter adapter
aem sri
apexi n1 cat back
HIDs
skunk2 shift weighted ****
Old Oct 15, 2009
wow how do you have so many miles?
Old Oct 17, 2009
Ckutch02EX's Avatar
Ckutch02EX is an unknown quantity at this point
2005
Manual
55,600 miles
ebay intake with AEM Dry flow filter
Yellow Fogs
N1 style exhaust(cat back)
RSX front leathers
Red H badges front and rear
Cool Blue head lights(soon swaping for projectors)
Jensen double din
DC5 shift **** and shift boot(boots a knock off)
Mugen oil cap
Mugen pedals
type-R lip(second one)
One eat, Sleep, Honda sticker worth 15 horse power lol
I'm the second owner and not one problem. Looks like it just came out of the show room. My old 2002 coupe, that's a whole different story. Poor car.
Old Oct 18, 2009
batman900's Avatar
batman900 will become famous soon enough
03 EX manual. 59k. No real problems just anoyances. Lots of rattles, squeeks, car doesnt like shifting when cold.
Lots of small upgrades, LCA bushings, strut bar, battery big 3, revo short shifter ect ect
CarStuff
Dec 6, 2020 12:52 PM
thana
Jun 15, 2020 07:05 PM
Marcus2thextrem
May 10, 2015 03:08 PM
tylerginevan
Apr 27, 2015 12:29 PM
MY01HX
Nov 12, 2001 04:25 PM
