Console Bulb Replacement: 2001 Civic
Old Sep 8, 2009
craddmd's Avatar
craddmd is an unknown quantity at this point
Anyone know how to replace the bulb underneath the automatic shifter in an '01 Civic LX 2-door? The P/R/N/D/D3/2 doesn't light up on mine anymore - most people would probably ignore it, but I'm **** like that. Can you just remove the shifter handle and the bolts that anchor the whole console assembly to the floor, then lift it up; or is it more complicated? The dealer apparently didn't want to deal with it - they said it would cost $100+. Thanks for any input.
Old Sep 8, 2009
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
Re: Console Bulb Replacement: 2001 Civic
It's most likely a cheap and easy way to it if you take the time. In all honesty it will take you 40 minutes your first time. All you pretty much have to do is remove the console, and then take apart the shifter.
Old Sep 9, 2009
you have to remove the entire center console to get to the bulb underneath.
Old Sep 9, 2009
CraigW's Avatar
You can access the bulb with the basic trim panels removed at top. It is on the drivers side. Twist socket to left to release and pull out. Wedge base bulb #74.
mattdoc
Mar 14, 2017 12:10 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
