coolant problem
Old Aug 26, 2009
dspeedcrazy02's Avatar
dspeedcrazy02 is an unknown quantity at this point
coolant problem
for some reason my overflo tank keeps coming up to high if no at the top.i replaced the themastat,water pump,and flushed the radiator out and it was good.has anyone had this problem before.i just cant seem to figure this one out
Old Aug 26, 2009
Ckutch02EX's Avatar
Ckutch02EX is an unknown quantity at this point
Re: coolant problem
Is it at high when the car is on or off? When driving does your temp gauge bounce?
Old Aug 26, 2009
04 Honda Civic's Avatar
Re: coolant problem
Does your car overheat? If it does chances are you have a bad headgasket
Old Aug 26, 2009
Re: coolant problem
no it hasnt over heated at all yet,when im driving on the freeway going 80 plus por smashing the resevoir goes almost to the top and when i turn the car off and let it cool down the level still stays high
Old Aug 27, 2009
cloud2987's Avatar
cloud2987 is an unknown quantity at this point
Re: coolant problem
Sounds like the thermostat to me.. but not for sure. I know that that the coolant flows through the system when the thermostat reaches a certain temp othewise it stays closed and only runs in the engine. I think you said you fixed the problem.. but you can test the thermostat by taking it out and putting in a pot of water and boiling it with a thermometer in it to see what temp it begins to open and what temp it starts to close... you'd have to find out what the specs on the thermostat are.. I never tried it but my professor (ASE master tech) taught my class that. Anyways good luck
Old Aug 27, 2009
Re: coolant problem
yes i just replaced the thermistat to a 170 temp about 200 miles ago.that is supposed to be stock temp.just got back from a 50 mile freeway run driving 70 or 80 ,and the overflow tank was over the max level, just a few inches from the top but not over flowed and no over heating. befor i left i put the level low.
Old Aug 27, 2009
TRIZ's Avatar
Re: coolant problem
I think you got air in your system. To get it out, do this..
Park on a level surface and when the car is cool, I mean completely cool, take the rad cap off. Fill up your reservoir so its at the halfway point between low and max. Turn the car on and let it idle till there arent any bubbles coming out of the rad, about 10 mins or so. Then turn car off, add coolant to the rad so its up near the top and turn it back on so any other bubbles come out. Repeat this till the coolant level doesnt drop. All air should be outta your system at this point.
Old Aug 27, 2009
Re: coolant problem
ok ill try that in the morning when i wake up ill get back to say how it went
Old Aug 27, 2009
TRIZ's Avatar
Re: coolant problem
Make sure your using Honda brand coolant, type 2 in your car. Dont use the prestone autozone stuff or whatever other brand- use strictly honda coolant.
Old Aug 28, 2009
Re: coolant problem
dont overfill ur resivior either.
Old Aug 28, 2009
Re: coolant problem
i like to keep a lil extra in there just in case. its got a long neck lol
Old Aug 28, 2009
nucivicowner's Avatar
nucivicowner is an unknown quantity at this point
Re: coolant problem
You may have a bad radiator cap. Replace with new. Make sure you get Honda cap. Bring your VIN # when you purchase the cap because the civic had two radiator manufacturers (at least the 2001 model did) and you want to match up the correct cap. Make sure your radiator fans are working. They are turned on when the temp sensor located in the T'stat housing detects a pre determined temp. The fans should come on while reving the engine just above idle speed/rpm and the engine is at normal operating temp. The fans will come on and go off after a few seconds. More than likely you have a blown head gasket and you are getting exhaust gases in your cooling system. The gases fill the radiator/coolant system and force the coolant out into the resevoir. Eventually the resevoir fills up and coolant burps out making a mess of the engine compartment. Eventually enough coolant will be lost and you will overheat. There is a test method for this issue. You can rent an exhaust/combustion gas tester from Autozone. It uses a glass tube and suction bulb to pull gases from the radiator. When the gases pass thru a blue liquid chemical it changes from blue to yellow if exhaust gases are present. If this is the problem the head must be removed, milled and new head gasket installed. The reason i know all of this is because i have just completed such a repair last weekend. I am currently monitoring the level of coolant in the resevoir and so far so good. I did have to replace one of the upper radiator hose clamps because it was leaking a little. Those spring ring type clamps suck.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
Jun 2, 2015 11:54 AM
Pongster
Jan 18, 2002 09:30 PM
