is the mechanic trying to rip me on control arms
Hi,
My front lower control arm bushings are shot on my 2002 ex.
Repair shop just gave an estimate of $900 dollars to replace both of the lower control arms, with $90 tacked on for an alignment.
Said they may be able to just replace the bushings but can't say over the phone.
Is that outrageously high or what? I see prices for new control arms around the $100 range, but this is a shop that I've heard lots of good things about (e.g. not cheap but honest and do good work).
Re: is the mechanic trying to rip me on control arms
It seemed pretty high to me. Maybe it was him that was high.
In terms of doing it myself, I've never done much on a car. Change oil, transmission fluid, brake pads, etc...
Do think an idjit could do it?
You can't really replace them yourself, it takes a press to do it. Energy Suspension sells a set of polyurethane bushings for $50. It's way cheaper than the oem replacement ones, or at least the prices I've found. What you can do is take the LCA out and take it to the shop to swap the bushings.
To simply replace the LCAs is easy and often much easier than trying to replace the bushings. From what you would pay to get new bushings, get them pressed out and back in, you're about 85% of the way to a new set of LCAs. About the only special tool you need is big hammer to knock the ball joint loose.
i thought $150 that sears charged me to replace the front bushings with ES parts was high lol.
I will be doing mine soon as well, but I'm going to put Energy Suspension bushings in so it does not happen again. As much as I agree with what speedfoos says, I'd rather have the better bushings in. But, I know someone with a press!
GolNat
Sep 10, 2015 08:25 PM
bryden13
May 18, 2015 12:22 PM
Pudnite
May 9, 2015 07:51 PM
