Aem ems?
Old Jul 12, 2009
03civicexR's Avatar
03civicexR is an unknown quantity at this point
Aem ems?
ok so far from wat ive searchd ive found notin at all. would doing the basic plug and play help my car run a little bit better wit basic mods or do i really need the uego as well. im not lookn 4 a big hp increase just make my engine less retarded to my mods. o yea and im not planning on goin wit k-pro (to much BS for me to get into)
Old Jul 13, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: Aem ems?
If you are seriously considering EMS, just go with the 30-1030 box. Don't worry about the extra expense of the 30-1030U (the one with the internal UEGO). With the U model, you can use a wideband for tuning and the EMS will use wideband feedback instead of just narrowband. But here is the kicker, you can't use a gauge to see your wideband reading unless you buy an AEM serial gauge. Here is an even bigger kicker, the regular EMS can use wideband feedback from an external wideband. Just buy an AEM, PLX or innovative wideband and wire the 0-5V output wire into your primary o2 wire to the ECU and tell EMS to use that signal and ignore everything else. As for the actual benefits of a standalone, they are fabulous. If you plan to turbo or swap, IMO it should be the first thing you do. If you don't plan to do either, its not really worth it for just bolt-ons.
carid
Nov 7, 2015 01:46 AM
naokigoffi
Aug 30, 2015 06:19 PM
spyder13
Jul 31, 2015 06:31 PM
Misfit2613
Jul 30, 2015 09:49 AM
Theshwartz35
Jul 17, 2015 11:13 PM
