some kinda super racing transmission.
Old May 4, 2009
Superjester's Avatar
Superjester has a spectacular aura aboutSuperjester has a spectacular aura about
Whats up Guys? It's been awhile.
So Recently I have replaced my whole transmission. Due to some problems. (2nd gear grind) and because I didn't want to open it up again.
After doing this swap once more I noticed something while driving.
I think the Junk yard kind of messed up here... They handed me off a vtec D17 transmission.
I rev at 4k about 120 km/h (canadian)
Redline to second powershift drops to about 5500RPM where is before it used to be
5th gear@60km/h is about 1,500 RPM
Does this sound right? or did I get some kind of power transmission here? i do notice thew gear ratios being together more
Old May 4, 2009
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
Re: some kinda super racing transmission.
stop slammin gears and you wont have a 2nd gear grind again. READ your manual and shift accordingly unless of course you like replacing your tranny and um the trans in all d17 civics are the same vtec isn't a transmission type
Old May 5, 2009
krarnold's Avatar
krarnold is an unknown quantity at this point
I too thought the gear ratios were supposed to be different in the civics with vtec. Anyone else thought that?
Old May 5, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Stop being a tool and handing out bad information. The second gear grind is most likely due to old fluid or a worn synchro ring. Try replacing the fluid. If that doesn't work, you will have to crack the case and take apart the countershaft. If your trans is from an 01-02 you will have to replace the whole second gear set along with the reverse counter gear and fork. Honda updated the gears and won't sell the older gears anymore.
The trans in an EX does have tighter gearing, first, fifth and the final drive are different. LINKY There are all of them.
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
krazykoncepts
Sep 8, 2015 09:02 PM
