What point must the rotors be replaced?
Old Mar 28, 2009
dpilot83's Avatar
dpilot83 is an unknown quantity at this point
I just changed my brake pads today with OEM pads. The rotor when measured at the widest point is 13/16th of an inch (I only checked one rotor). Does it need to be replaced? Thanks.
Old Mar 29, 2009
CraigW's Avatar
Re: What point must the rotors be replaced?
The min thickness in metric should be marked on the rotor towards the center area. I don't turn rotors any more. If they get warped ( I'm easy on brakes) then I just replace them.
Old Mar 29, 2009
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
the min spec on the front rotors is 19mm. the thinner the rotors get the more prone to warping they get. so keep an eye on them
Old Mar 29, 2009
02_civiclx's Avatar
02_civiclx is an unknown quantity at this point
Two cents: Don't mess around with your brakes. Any indication that it needs replacement, replace it.
Old Mar 29, 2009
dpilot83's Avatar
Thanks guys. 13/16 of an inch is almost 21 mm. I think the side I checked is quite a bit more worn than the other side. The other side I was worried I would be unable to get the new pads to go on. I guess I'll replace them if they get warped or otherwise I'll wait until the next time I have to replace the pads.
bsmiley
Apr 27, 2015 01:27 PM
McD
Apr 16, 2015 10:46 AM
tattedlariat
Apr 12, 2015 07:55 PM
thesushiboy
Apr 12, 2015 02:54 AM
domesticsnyper
Jan 8, 2002 11:29 PM
