under the hood
Old Jan 31, 2009
oscar meza's Avatar
oscar meza will become famous soon enough
under the hood
i want everything under my hood washed n cleaned..getting too dirty under there
do any of u guys no a good place in so cali areacode 626
that does a good job on cleaning under the hood??
if so let me know
thanxx
Old Jan 31, 2009
TRIZ's Avatar
Re: under the hood
Find a steam cleaner and spend a few hours in there getting personal, then use some hyper dressing, will look like new.
Old Mar 9, 2009
oscar meza's Avatar
Re: under the hood
o0o k thanx TRIZ
Old Mar 9, 2009
oscar meza's Avatar
Re: under the hood
Wait i know im suppose to cover some stuff up with like a plastic bag can u help me out with that?
Old Mar 9, 2009
Re: under the hood
i would just use some degreaser and work one section at a time. no need to spray water and possibly ruin things. engine bay wasnt designed to get wet. most of the time you just need some degreaser and a rag. and maybe some plastic protectant and metal polish if you wanna get it ready to show or something.
Old Mar 9, 2009
lowlife9's Avatar
Re: under the hood
simple green
Old Mar 9, 2009
Re: under the hood
it messes up some metal surfaces
Old Mar 9, 2009
IRPancake's Avatar
IRPancake is an unknown quantity at this point
Re: under the hood
if you have an open filter, obviously cover it with a plastic bag. you can also do the alternator if you'd like, everything else shouldn't matter, don't do it when its hot! Spray some simple green and wait 10 or so minutes, then hose it off. Then go in and wipe it down, on the plastic pieces use back to black or tire shine or something along those lines.
Old Mar 11, 2009
fiend's Avatar
fiend is an unknown quantity at this point
Re: under the hood
so is the best way with a degreaser and rag? where are you getting steam cleaners small enough to work the engine bay at, walmart?
Old Mar 11, 2009
unTuned's Avatar
Re: under the hood
like gearbox, i also only use degreaser. i do however use water though. just spray degreaser all over and leave it for a few minutes, id say 4-5 minutes should be alright. once youve done that give it a light spray, or a spray from a bit of a distance and you should be ok. just make sure you put a plastic bag and tape it up around your air filter and around your alternator, you should be just fine. nothing else in your engine bay will get much harm from some water. at least ive never had a problem doing it this way and i do it in the spring, middle of summer, and fall...3 times a year.
Old Mar 11, 2009
fiend's Avatar
Re: under the hood
^word
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
rnaodm
Sep 21, 2015 12:42 PM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
