Header/Test pipe????
Old Dec 10, 2008
EM2 RYDER's Avatar
EM2 RYDER is an unknown quantity at this point
i have searched and could not find out the answer to my question. I have an Apexi catback on right now and im buying a dc 4-1 header for real cheap from a friend, but its just the upper section. So i was wonder if the DC header will hook up to the megan test pipe that takes place of the whole cat piping?
Old Dec 11, 2008
JoshD's Avatar
JoshD will become famous soon enoughJoshD will become famous soon enough
Re: Header/Test pipe????
It probably should. I didn't even know megan had a test pipe out for the EX.
With all of that strait pipe, I would throw a resonator in there somewhere to cut down on raspy-nastyness.
Old Dec 11, 2008
ronaldo9's Avatar
The megan test pipe should bolt up to the DC if the DC is the same size as the Megan 4-1. Megan's test pipe has been out a few years for the EM2.
Old Dec 12, 2008
EM2 RYDER's Avatar
thanks alot another question though...whats the best way to go at tricking the o2 sensor that plugs into the cat?
Old Dec 12, 2008
ronaldo9's Avatar
Spark plug non fouler IMO.
Old Dec 12, 2008
supafil25's Avatar
supafil25 will become famous soon enough
2 of these
like this
Old Dec 12, 2008
Fox04coupe's Avatar
Fox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond repute
mine doesn't have anything.... EX header, megan downpipe, no defouler. it doesn't throw a CEL. probably cuz it only has 60k on it.
Old Dec 14, 2008
EM2 RYDER's Avatar
well heres the deal, one of my friends crashed his em2 so i got his dc prototype header off him (4-1) and a magnaflow high flow cat. whats the difference between prototype and a regular dc header
Old Dec 15, 2008
EM2 RYDER's Avatar
as long as i put those foulers after the high flow cat i shouldnt throw any codes rite??
Old Dec 15, 2008
supafil25's Avatar
if you install the high flow cat you dont need defoulers at all. because you still have a cat.
when you get ride of the cat with a test pipe then you need defoulers or your gonna have a CEL
Old Dec 15, 2008
ronaldo9's Avatar
True but many companies market "high flow cats" but are really test pipes.
Old Dec 15, 2008
EM2 RYDER's Avatar
ya mine is like honeycomb inside, you can see right through it but theres no hole for the o2 sensor so i have to put in one of those after the high flow...and another question when i drill the hole for the fouler does it have to be at the same angle?
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Cam Diaz
Sep 29, 2015 07:17 PM
michael0219
Sep 1, 2015 10:25 PM
PierrePierre
Aug 12, 2015 02:42 PM
Causemo
Jul 5, 2015 06:42 AM
