04-05 civic si guages...
Old Dec 6, 2008
o4hondaskivic's Avatar
o4hondaskivic is an unknown quantity at this point
Cool 04-05 civic si guages...
i got a 04 civic dx...i was wondering what it would take for me to put the 04-05 civic si instrument cluster...would it work...im wondering if the harnesses would plug up and if the mounting hole will line up..any one know?? thanks
Old Dec 6, 2008
Fox04coupe's Avatar
Fox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond repute
Re: 04-05 civic si guages...
you would probably have to do lots of custom work, cuz i'm pretty sure the bezel doesn't fit right or something. you would have to look up how to wire it, it would definitely not be plug and play. i have a 04vp and you would have to do some rewiring of pins to get a lx/ex cluster to work. 01hondercivic is the man at stuff like this. look at my sig for a start.
Old Dec 6, 2008
are you in canada? if yes then it will work, you just gotta do some rewiring of the pins.
Old Dec 6, 2008
supafil25's Avatar
supafil25 will become famous soon enough
im putting in a rsx cluster into my 02 lx and it fits just gotta do the wiring
Old Dec 6, 2008
how did you manage that
Old Dec 7, 2008
Cool Re: 04-05 civic si guages...
thanks alot
Old Dec 7, 2008
supafil25's Avatar
lol idk i havnt started yet. but someone else on here did it and said you just cut the plugs off the harness and match up the wires by color and solder them with the new clips to the rsx gauges.
Old Dec 7, 2008
redem's Avatar
redem is an unknown quantity at this point
http://www.honda-tech.com/showthread.php?t=2204667
try this out, i think it's really is to follow and i'm going to do it soon
Old Dec 8, 2008
how about mounting thr rsx cluster. dont expect it to bolt right up and fit with the stock bezel
Old Dec 8, 2008
redem's Avatar
hey gear box, your right, it won't fit properly, but like it says in this diy, you have you look where it doesn't fit properly and dremel that part CAREFULLY!!
http://www.honda-tech.com/showthread.php?t=2388664
Old Dec 8, 2008
supafil25's Avatar
cant wait to do mine just need some heat shrink tubes
Old Dec 12, 2008
aspech's Avatar
aspech is an unknown quantity at this point
i did the rsx in mine. picked up the cluster/plugs and just rewired. simple slapped in it and it looks sick. new cam in there too so the redline is legit
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
Lightman
Nov 10, 2001 06:44 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
