Power Slot big rotor kit
Old Nov 18, 2008
GotToyota?'s Avatar
GotToyota? is an unknown quantity at this point
http://www.corsportusa.com/store/cat...roducts_id=158
Does anyone have any experience with the Power Slot big rotor kit for our car? I'm thinking about buying this.
Old Nov 19, 2008
Kevbotron's Avatar
I like my commute
Re: Power Slot big rotor kit
if you get those you should get larger calipers too.. running stock calipers on bigger rotors wont make **** of a difference.. the pad is still hitting the same surface area. I'm running PowerSlot rotors of stock size and I upgraded my pads to Hawk's
now i'm uber grippy to the road
Old Nov 21, 2008
supafil25's Avatar
supafil25 will become famous soon enough
not quite true
getting bigger rotars and keeping your stock calipers will make a big diff. when you upgrade to bigger rotars the diameter and circumference increase so the pad has more area to cover while the rotar turns. makes for better cooling as well
Old Nov 22, 2008
Fox04coupe's Avatar
Fox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond repute
hahaha, definitely... it's like using a sissy bar with a wrench, better leverage.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Supramk3
Jun 11, 2015 11:13 AM
bsmiley
Apr 27, 2015 01:27 PM
supercivic01
South
Nov 30, 2001 11:27 AM
