rear speakers
Old Oct 2, 2008
unTuned's Avatar
rear speakers
i just got some infinity kappa 692.9i and im going to install them. for any of you that have them, you know that they come with a little terminal harness thing that takes a positive/negative wire. i noticed that the stock speakers are connected with a harness and will unclip...how did you guys connect that to your new speakers? did you cut the harness off and then feed the positive and negative wires into the new speakers?
Old Oct 2, 2008
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Re: rear speakers
You can either buy the adapter that goes from the adapter to go to the positive negative or just cut the wires and wire in the supplied wires. I would just cut the wires.
Old Oct 2, 2008
unTuned's Avatar
Re: rear speakers
ok well im taking it that all of the aftermarket speakers will take just bare wires like these infinitys do?
if thats the case then yea ill cut it. i just dont want to run into the problem of changing speakers one day (if i ever decide to) and need that harness again, but if its only for the stock speakers, its np because ill never use those again.
Old Oct 2, 2008
Re: rear speakers
i just wrapped bare wire around the actual speaker terminals. using the spade connectors, i got bad static cause they would always jiggle and get loose. you will never go back to stock speakers, NEVER.
Old Oct 3, 2008
unTuned's Avatar
Re: rear speakers
well these speakers come with places to put the wires in and screw them down. heres a picture..
http://www.sonicelectronix.com/images/normal/6929i.jpg
i guess that since that harness is only good for the stock speakers, ill just get rid of it. i know i wont ever put them back in because if i ever change speakers again, it will be to other aftermarkets. thanks guys
Old Oct 3, 2008
Re: rear speakers
oh yeah those are nice connections
Old Oct 4, 2008
unTuned's Avatar
Re: rear speakers
yea hopefully at some point this week ill have time + daylight to get it done. i checked on crutchfield.com before i bought the speakers and it says they clear in the rear deck from that trunk spring...hopefully it works out.
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
jpat21
Sep 3, 2015 11:32 PM
jpandjf
Aug 3, 2015 05:02 PM
Nalmonte
Jul 22, 2015 09:08 AM
