ebay projectors, good or not?
Old May 17, 2008
ahailey's Avatar
ahailey will become famous soon enough
So I see all these projector headlights on ebay for cheap, do you guys know if they're any good? And can I use HID's with them?
Old May 17, 2008
Tragedy's Avatar
skate or die
Re: ebay projectors, good or not?
I once bought a pair from ebay. They blue ring stopped working after a couple months, and the bulbs have fittment isues inside the housing.
ebay parts =
Old May 17, 2008
the projectors suck for output and i dont think they are even legal. my aftermarket cheapie foglights work better than those. and with hid, i think it will look even worse. dont bother unless you plan to swap out the projector assembly with something better (which is easy to do).
Old May 17, 2008
ahailey's Avatar
the ones i look at say DOT approved, but i don't know. I like how they look i just want some that WORK good too. Are there any out there that actually do work pretty well?
Old May 18, 2008
SpiderX1016's Avatar
SpiderX1016 is an unknown quantity at this point
It's not worth the time and money.
If you wanted HID, look into Retrofitting them.
Old May 18, 2008
dj_cronic_metal's Avatar
dj_cronic_metal will become famous soon enoughdj_cronic_metal will become famous soon enough
To retro does it have to be a projector or can it be done with a regular headlight?
Old May 18, 2008
i can put a dot stamp on anything. i guarantee you they did not get an actual D.O.T. approval because it costs alot of $$ for them to have it certified. every aftermarket lamp ive seen failed to meet minimum oem standard of light output in independent testing. the stock headlights are actually the brightest ive used out of all the aftermarkets out there. projectors and oem "style" lights included.
if you want a light boost, go type in "catz zeta" in ebay and buy one of those kits. it comes with ballasts that connect to the stock 55w bulbs and basically it will boost the voltage from the stock 13-14v to over 15v which makes each bulb over 500 lumen brighter. its like having a third headlight on your car. i actually still use the kit in my fog lights now that i have hids for my main beam. the halogen fogs with catz zeta is bright enough to drive on the road at night without headlights.
carid
Jun 5, 2015 11:51 PM
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
