exhaust help?!?!
Old May 8, 2008
redem's Avatar
redem is an unknown quantity at this point
exhaust help?!?!
i have a 2001 dx and have a magnaflow cat back, i'm planning on putting the v2 and was woundering if i should go through the trouble of buying the ex header and uni high flow cat or stay stock for headers....someone help?!?!
Old May 8, 2008
Re: exhaust help?!?!
stock header works fine, the ports are already the same size as the engine so going bigger usually causes performance loss.
Old May 9, 2008
dswami1's Avatar
dswami1 will become famous soon enough
i hear doing hi flo cat usually makes exhaust louder...just so u kno
Old May 9, 2008
redem's Avatar
so just go with the v2 and i should still have good air flow ?
Old May 9, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
the ex headers and a cat deletion could add about 10hp. just make sure you have an O2 simulator.
Old May 9, 2008
khanselman's Avatar
khanselman is an unknown quantity at this point
The problem with the DX header is the cat is built right onto the header and it's pretty restrictive. yeah, doing some headers and cat-delete will help a bit (and be illegal).. if you don't get the CELs... but doing a header / high-flow cat is better.. There was an article about it somewhere showing that a high-flow is actually better than cat-less, I'll see if I can find it.. plus it's legal.
Not only does it give you a bit of a kit over the stock header/cat it will make the exhaust a bit deeper / louder - but not annoying.
And, just an fyi - I just so happen to be selling an 01-03 DC Sports 4-1 header (with o2 sensor extension cord for the DX) and a Random Technology High-Flow cat w/ dezod install kit. PM if interested.
[EDIT]
Here's the article I was talking about - http://www.importtuner.com/tech/impp...ers/index.html
Old May 9, 2008
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
Originally Posted by Envy
the ex headers and a cat deletion could add about 10hp...
yeah and blown ear drums and angry neighbours...
Old May 10, 2008
redem's Avatar
wow, thanks guys, you've been a lot of help
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
jtcavey
Sep 30, 2015 02:18 PM
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
