New Rims are On BUT!..
Old Mar 21, 2008
carter's Avatar
carter is an unknown quantity at this point
ILl have pictures up but one problem.
I was tightening the bolt on my wheel and one of the four happend to crack... The thread is on all the way but the key that fits into the lug spins free because the bolt is cracked??
I got extra ones now any clue what to do with that??? I thought i would take the other 3 off when i look to change my brakes later on and try to twist and turn and bend hopefully the rest of it cracks and it comes off but im not shore what to do..
Old Mar 21, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: New Rims are On BUT!..
What exactly did you crack? Sounds like you stripped either the hub or the lug.
Old Mar 21, 2008
carter's Avatar
The lug nut.. the "Bolt".. Cracked from the side.
Old Mar 22, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
did you torque it too tight? id put stockers on and go buy a new bolt. dont roll with different sets of wheels.
Old Mar 22, 2008
carter's Avatar
i have a new bolt how do i get it offf?
Old Mar 22, 2008
carter's Avatar
Also i noticed the rotational patterns for the front left and the back right are reveruse the arrows pointing backwards and for the front right and back left the rotational arrows are correct.
There were lines on the tires the ones closest to the face of the rim for both tires went on the front and the ones closeest to the inside went on the back i paired them up is that okay?
Old Mar 22, 2008
TRIZ's Avatar
okay, just to point something out to make this thread a littler clearer...
Bolt is on the left, which in your case would be the stud on the hub
The nut is on the right, which would be your "lug nut"
So please use the correct names and call it a lug nut and not a bolt, and vise-versa
That being said... what did you crack exactly?
Old Mar 22, 2008
greeen01civic4d's Avatar
haha triz, im confused as well
Old Mar 22, 2008
DeX's Avatar
DeX
Canadian, Eh!
Ya, this guy's calling nuts bolts and what the ****. I don't get it either.
Old Mar 22, 2008
blackonblack's Avatar
blackonblack has a spectacular aura aboutblackonblack has a spectacular aura about
sell your car
Old Mar 22, 2008
carter's Avatar
Lug Nut ( I thought the word LUG refferd to the "Lug Nut" i guess not.
My Bad.
Old Mar 22, 2008
carter's Avatar
These are the pictures :>
Old Mar 22, 2008
Envy's Avatar
Diamond Member
looks nice. hard to believe those are 18's.
Old Mar 22, 2008
DeX's Avatar
DeX
Canadian, Eh!
So you cracked one of these and now can't get it off?
If you got a grinder or cutting tool, just cut right into the side of it and trash it. Otherwise I would try jamming a flathead screwdriver into the crack and try to split it all the way through. You're going to have to get the nut off without wrecking your hub somehow.
Old Mar 22, 2008
carter's Avatar
Thanks for the help :> Illl try that
I think from the looks of it i could go 205 or 215 40 intsead of 35/18 on the tires. I guess ill look into that after a few summers
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
Balkos
Sep 11, 2015 11:39 PM
