Error Code : P0401
Old Mar 19, 2008
elg_tsakura's Avatar
elg_tsakura is an unknown quantity at this point
Error Code : P0401
Hi all,
My ride : ES 1
engine modal : D17A9
I encountered a problem which surfaced after I have changed my pistons.
Error Code : P0401 Exhaust Gas Recirculation (EGR) Insufficient Flow
Orginal specs : Compression ratio :9.90:1
Bore : 75mm
piston swapped : Compression ratio : 8.80:1
Bore : 75.5mm
Stock gaskets
After putting in these pistons, the check engine light would lite and not go off. I realised that the ECU will detect a 2 cycle warning before lighting up.
Anyway, I could not solve the CEL issue.
even after cleaning the throttle body, EGR valve (New set), EGR passage way this problem still persists.
I have also tried blocking the EGR valve passage with an addtional 1mm gasket.(in attempt to allow the EGR valve to "lift" higher to compensate the compression lost. FAIL
Tried using a bigger bore EGR valve - FAIL
Can anyone who has experience with this error code or CEL issue advise me?
I believe many guys ard have changed to a lower compression piston.Wonder if you have encountered this same problem???
Appreciate all inputs!!!
Cheers!!!
Thanks !!!
Old Mar 19, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
Re: Error Code : P0401
are you sure its a D17A9?
Old Mar 19, 2008
speedfoos's Avatar
Yeah, that's the Euro version of the D17A2. Same bottom end, slightly smaller valves on the head to give it better emissions specs.
As far as your error code goes though, probably the only way to fix is a standalone, unless you're good with electronics. You would have to simulate the stock EGR signal that the sensor sends in order to ditch the CEL without going to a standalone. To do that though, you'd have to figure what the stock voltage is that it would send and get some kind of potentiometer to add voltage to the signal - basically really complicated - in order to simulate it.
Old Mar 19, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
what code it P0401?
why did you swap out the pistons?
Old Mar 24, 2008
Yes its a D17A9. I am residing in Singapore. I am going to try the standalone (Honda Kpro). Currently I am using Emanage but this piggyback does not have the function to solve this issue.Hopefully by changing to the Kpro would help solve this problem.
Thank you Speefoos for your explanation.However, its really too complicated Haha.Appreciate your valuable information.Maybe I will try with the Kpro and hope that everything goes well.
Initially, I wanted to swap the pistons together with the con-rods however, my rods got delayed and since my engine was already stripped and because of the time constrain I had to do without the rods.
I believe there are many D17s around that have swapped the pistons to a lower compression.was wondering whether anyone had the same issue as me?If not, what standalone ECUs or piggyback that is used?
Hope to hear from you guys soon.
Cheers!!!
Civic15
18
Sep 19, 2017 07:48 PM
mjdiaz89
Jun 21, 2016 09:26 PM
jessica19699
Jul 29, 2015 05:51 AM
Green02civic
Jul 27, 2015 10:48 PM
cgavin1
Jul 7, 2015 07:10 AM
