What does the little red button do?
So, I've had my Civic for almost 7 years now, and I've always wondered: what does that little red button sort of built into the driver's footrest do? You know, this one:
Re: What does the little red button do?
Actually come to think...Honda as they built your Civic knew that you were strugglin wit a bad set of females so they installed that so wen they give you lip...just press it and well out the sunroof they go...so u bes give Honda a pat on the back for that one!!!! If you look close under one of the panels you probably have a label that says 1 of 10...consider yourself lucky! LMAO!!!
Haha, thanks for the humor guys. Yeah, I'm the original owner. Turns out, it is just a bolt (it won't push in like a button or anything). Can't think of why it's painted red unless it's just because the car itself is red. I saw a an older (5th gen) Civic coupe on eBay that was red and had the same deal on it's footrest. Anyway, thanks for input...
Welcome to the idea of a lean production system- to reduce costs through streamlining the assembly and to maximize efficiency. If you look closer, you'll see its not the head of a bolt, and that the threads are pointed up and a nut threads down to hold it all together.
FYI- Mechanics paint the tops of bolts all the time for reference cues- like if a mechanic strips the bolts on your air box, he might paint them yellow to give who ever is under the hood a clue that something up. They also use dabs of paint during inspections- kinda like how you use check marks when doing something complicated on paper.
BTW, very clean interior
hmm.. tt looks familiar.. i have it on my steering column.. still tryin to figure out wad it does.. pressed it n nothing happens.. got it with after my alarm system installation..
hondacivic0253
Sep 29, 2015 08:06 AM
Touge
Sep 18, 2015 12:13 AM
Civic720
Sep 10, 2015 10:06 AM
hatch90
Sep 3, 2015 08:45 AM
Touge
Sep 1, 2015 11:25 PM
