Hid Kit Install Helpppppp!!!
Old Nov 23, 2007
MDCIVIC28962's Avatar
MDCIVIC28962 is an unknown quantity at this point
I Just Bought A H4 6000k Hid Kit And I Dont Exactly Know How To Install It... I Apparently Have To Do Something About The Relay? Im New At This...help Would Be Appreciated
Thanks
Old Nov 25, 2007
ALLxIn's Avatar
ALLxIn is an unknown quantity at this point
Re: Hid Kit Install Helpppppp!!!
from what i understand since i have a buddy in the HID business that all hid kits should be in a form of plug n play. I have a 00civic myself too.. using H4. there should be an input to ballast and output. If you dont have the plug n play kit then you need the relay to plug into battery. Shouldnt be that difficult. Battery plug positive and negative wire.. then there should be a shocket to put into your factory plug.
Old Nov 25, 2007
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
Thanks
damn dude its only comin the 28th lol what u stressin already. anyway, just remember that the kit has reverse polarity
Old Nov 25, 2007
you need a relay harness that draws power directly from the battery to the hids and only gets triggered by the stock harness. that way you wont cause a fire.
Old Nov 25, 2007
yeah well do u know how it gets hooked up?
Old Nov 28, 2007
ALLxIn's Avatar
there's a positive (red) n negative (black) wire to hook directly to the battery pretty simply.
Old Nov 28, 2007
Technical Assistant
and the other wires can just be left to dangle right...if you dont know, why answer
Old Nov 28, 2007
lordhelmet's Avatar
... Rep for you if I can.
edit: I cant
Old Nov 30, 2007
Technical Assistant
edit: I cant
lol you can always try again in a few hours
Shane, glad to hear you got everything hooked up. Post some pictures man!! I wana see how my lights look on your car...oo and iTrader when u get time
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
Youshoe
May 22, 2015 09:36 PM
Maximus
Bolt-on Engine Performance
Nov 14, 2001 10:52 AM
SneakerPimp
Nov 3, 2001 10:57 AM
