Short Shift....thoughts
Old Nov 5, 2007
trubluciv's Avatar
trubluciv will become famous soon enough
i think this is going to be my next mod....any thoughts......
http://www.dezod.com/pd_bm_short_thr..._including.cfm
Old Nov 5, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: Short Shift....thoughts
i keep meaning to buy one myself, but i havent seen any real feedback on this?
i know the shifting is a tad sloppy on these civics, but not bad enough to kill you? so are these Short shift kits worth the buck?
i really would like some feedback myself!
Old Nov 5, 2007
03_Civic_Si_PA's Avatar
03_Civic_Si_PA is an unknown quantity at this point
As far as short shifters goes, you just have too look online at different forums, thats what I did when I had my 1998 Civic Si, I went online and I found out some things then I went from there, one thing I would say is do research on who and where you buy from, it really all depends on how much money you are looking to spend on it. I had bought a short shifter and a stage 3 racing clutch by XTD together for $200 brand new only because I got lucky and I was shopping around, as far as getting a short shifter it defintly is a lot nicer shifting gears because your not in neutral as long if your racing, but really its up to you and how you drive. Do you want that extra second of acceleration..... Of course you do. lol
Old Nov 5, 2007
FGCOUPE's Avatar
okay this may be stoopid *** **** but....
you said "it defintly is a lot nicer shifting gears because your not in neutral as long if your racing", now by this do you mean there is no actual "N" in between gears? what i mean by this is do you have to be on the clutch to the floor at all times like say at a light? or can you still let off the clutch with the car running/idle?
man...im gonna hear bout this one......
Old Nov 5, 2007
I mean, when you press on the clutch your stopping your engine from continuing to move forwards, its considered neutral. A short shifter minimizes the movment in throw between gears. Just because you have a short shifter doesnt mean you cant let off the clutch in idle. the mechanics are still the same your just replacing the shifter alone. Got it?
Old Nov 5, 2007
FGCOUPE's Avatar
ahh....ok thanks.
Old Nov 5, 2007
mad_ox1's Avatar
mad_ox1 will become famous soon enough
Instead of having to move the shifter 4 inches down to go from 1st to 2nd (for example), it will only need to be moved 3 inches. Yes, you can still leave it out of gear in nutral w/ the clutch out.
Old Nov 6, 2007
koketsucivic's Avatar
koketsucivic is an unknown quantity at this point
I've also been looking into this lately...
All info would help me also
here goes a few adaptors and a Revo Unit that I've found
TWM Shifter Adaptor
Revo Technica
DC Shifter Adaptor
Old Nov 6, 2007
knight_321's Avatar
knight_321 has a spectacular aura aboutknight_321 has a spectacular aura about
with the B&M SS will i be able to use the 1 that come form a type R is it the same as the tyse S?
cos ive found 1 new for $100 will it be worth it
Old Nov 6, 2007
FGCOUPE's Avatar
so how are TWM short shift kits?
Cuz im thinking on buying a kit from them which comes with:
- bronzoil cable bushings
- shifter bushings
- base bushings
...and the shifter adapter are CNC machined from high strength steel
Old Nov 6, 2007
- shifter bushings
- base bushings
My friend has a TWM shifter for his Matrix and he also installed the bushing set. He was the one that actually pointed me to them. He said the customer service from this company is awesome and the products they carry are quality built. These are his words not verbatim but in general. I was leaning towards ordering that kit myself for the Civic. From what he has told me.
Old Nov 6, 2007
trubluciv's Avatar
when you buy the kit what parts do you need for it......like what is the bushing set.....
so what should i look for when buying them.....
or do all the things i need come in a set together.....
Old Nov 6, 2007
Originally Posted by TWM Website
The CNC machined, billet aluminum shift adapter for the 2001-2005 Civic bolts rigidly to your shifter to reposition the shift cable and reduce the throw by 37%. Four billet aluminum bushings provide a much more solid contact point between the shift assembly and the floor pan removing all of the flex or play in the stock shifter.
If your looking for a "shorter" shifter the Revo and B&M will be the way to go.
The TWM and DC adaptor kit re-positions the actual stock shifter for less throw time. I think the bushings just adds to the rigidity of the shift being thrown. Hopes this helps.
Old Nov 6, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
get the REVO one
Old Nov 6, 2007
d17civickid's Avatar
d17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of light
im selling a fidanza short shifter adapter... if anyone wants let me know..
Old Nov 6, 2007
greeen01civic4d's Avatar
get the revo, for 100 bucks it is a great mod, i have one and in know foos does too, i love mine, its 40% reduction in throw, and really easy to install too, and its a whole lot cheaper than the b&m
Old Nov 8, 2007
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
you guys should know that you can do the same thing by cutting off the bracket and moving it up 3/4 of an inch or so. you can probably take the shifter out at someones shop and have it done for like 20 bucks. Mine looks like factory and I didnt add any weight with a bolt on peice. I added those bushings from that cap yoda dude and put them in as well. My throw is only about 2.25" if that, front to back and it shifts like a million bucks. I actually took 1/2 inch off the height while I was at it, and tigged it in all purty. Its made of real high quality **** and it welds up awesome. I actually broke a shifter cable a year or so ago being an idiot so theres certainly no issues with strength.
Old Nov 8, 2007
pedigree's Avatar
pedigree can only hope to improve
same i've been meaning to get one but i still have my stock engine
wouldnt it be better (and prolly cheaper) to get a new tranny with a new engine/swap???
Old Dec 10, 2007
I went with the DC shift adaptor. Was really easy to instal just make sure the allen bolt is threaded all the way through. The allen bolt was the only snag I found but once I figured that part out it was pretty easy. Took about 15 minutes for the whole install. The throw is nice and solid.
Old Dec 12, 2007
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
just get the revo. It reduces throw by 40%, is super easy to install ( just take out the old shifter assembly and put the new one in its place) and it cuts the height of the shift **** by about an inch...depending on the shift ****. Shifting is much crisper and faster. It's got to be, short of boosting, one of the favored mods on this site.
Old Dec 12, 2007
trubluciv's Avatar
so....this is what i should put on my christmas list.....
http://www.autodynamic.com/detail.as...SS-REV-HC01-G2
Old Dec 13, 2007
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
I wouldnt advise this but I would do it 100 times again
I just bought one of these things
used some JB weld to keep it from rattling and coming off.
Then I cut the shifter shaft that the handle screws on to and grinded it down until the pleather cover and handle could fit on. I then put the shortened shaft back on by welding and what was left of the JBweld. I only flick my wrist to shift now. It has worked fine for about 3 years now. If you plan on doing this pick up a spare shifter assembly before you start cutting and grinding.
Warning. this idea comes from the guy who recomends removing the passenger head rest(when driving solo) and placing the 2 metal bars between the center console and the passenger seat to make a free arm rest.
Old Dec 13, 2007
The only thing I've read about the Revo is that the screw can become stripped if adjusted too much. Other then that nothing but great reviews. I like the height of the stock shifter but wanted to shorten the actual throw between gears. I'm a little taller so I like resting my arm on the arm rest when shifting. Thats the reasoning behind me getting just the adaptor kit.
Old Dec 14, 2007
trubluciv's Avatar
ok....i did however look online at the revo shifter and it says it comes with a lifetime warrenty.....
http://www.revotechnica.com/racing_short_shifter.htm
so if something does get broken.....i can always get it fixed for free......
and do i need to get a new shift **** and a boot or does the stock one fit the revo one
Old Dec 15, 2007
The Revo should be threaded just like the OEM shifter. The boot will fit but will be a little "bunched" up more due to the shifter being shorter. Look at some pics of some em2's with short shift levers
Old Jan 3, 2008
SmUrFf's Avatar
SmUrFf is an unknown quantity at this point
Planning in getting one too... I just wanted to know, how is the quality of the REVO short shifter? Thanks in advance.
Old Jan 22, 2008
Papa Pepperroni's Avatar
Papa Pepperroni is an unknown quantity at this point
Hey,
I just recently got the B&M short shifter for my 2001 Civic EX. And I loooove it! It's so much better than the stock shifter. In addition to the short throw (It gives you the option when installing for 25% or 35% reduction, I went with 35%) , it also is much sturdier feeling than the stock shifter. It's not rigid or anything, it just feels much more solid. I would really suggest getting the B&M shifter, I have nothing else to compare it too though, besides the stock setup. Installation was a breeze.......yes installation....about 40 minutes....BUT...taking the stock shifter housing out of the car and removing the shifter from the housing.....took wayyy to long. Probably about 2 hours or so. Everything you need to install the shifter comes with the B&M kit, besides tools. Sooo, I love it. If you have any questions or I missed something, let me know.
Old Jan 24, 2008
bluecivic_19's Avatar
bluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the rough
get an OBX type r short shift, reduces the throw by 30% i got 1 and its the best
Old Jan 24, 2008
speedfoos's Avatar
Pics of the B&M and OBX shifters (by themselves and installed)?
Old Feb 1, 2008
Wolfgang5884's Avatar
REVO and aluminum bushings for the win!!!
