question about the 1.7 non vtec
Old Oct 22, 2007
monkeydude3's Avatar
monkeydude3 is an unknown quantity at this point
Just a quick question here. I have a 2004 Civic LX 5 speed. It has the 1.7 "Non Vtec" engine. There is a guy in my auto class who has a decked out Civic and 'apparently' knows a lot about Hondas. He said my 'Non Vtec' has something resembling Vtec on the exhaust cam lobes that Honda started to do in the mid 90s?
Is he right or not? Not that it makes a difference, but I'm just curious.
And while on the topic of the 1.7... what kind of longevity does this engine have? I have 65000 on it and have owned it since 55000. I have full dealer warranty up to 100k and have been having them do full synthetic oil changes since I bought it. Doesn't use a drop of oil and gets average 35+mpg (few times I've seen 45mpg)
Thanks!
Old Oct 22, 2007
HighBoost's Avatar
HighBoost is an unknown quantity at this point
Re: question about the 1.7 non vtec
yea.. hes right..
what kind of longevity does this 1.7 engine have ? do a research i guess. too long to explain
so far ur car runs good.. is a good fuel economic car lol
Old Oct 22, 2007
Okay, that's kind of neat. The guy seems like kind of a tool so I thought I would double check. I just wanted to research it more.
Since it is true... what RPM is it supposed to kick in at? It it something I can even feel? I tried google and such and haven't found any information regarding it.
Thanks!
Old Oct 22, 2007
DsevenEm2's Avatar
This is Myspace
wait what? no wat the hell that isnt right. i dont think it is. im pretty damn sure thats not right. our 1.7L vtec motors do have what hes talking about. its not "true" vtec meaning the cam lobe changes on the exhaust side. but the non-vtec d17s dont have any kind of cam lobe change.. or else whats the point of the d17 vtec that i have lol
if u dont have vtec..then u dont have it, in any way shape or form. or you can have a motor that says vtec.. and is in one way or another.. vtec lol hes probably just talking about SOHC VTEC.. since sohc isnt true vtec its more like a fuel saver. even if u do have it.. it doesnt really "kick" in... it activates but u wont feel anything.. so knowing wat rpm it comes in at doesnt really matter..
Old Oct 23, 2007
Hmm... because he distinctively said the "non VTEC" engines have some sort of exhaust feature that locks the valves to the lobe...
either I'm hearing things or the engine changes it's tune a little between 3000-4000 rpm... or that could just be me winding out a tiny engine...
hmm
I'm just wonderin about what's under my hood is all
Old Oct 23, 2007
d17civickid's Avatar
d17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of light
that is just your powerband... every engine has a powerband... the lx you can really feel it after 4000 rpms... thats if you have mods... stock i think you dont feel anything....
Old Oct 23, 2007
Okay. I know cars pretty well just not much on the design of newr Hondas.
For a 1.7 rated at 105hp, it does kick pretty nice up to 6800 rpm
Old Oct 23, 2007
sentbacktothesu's Avatar
sentbacktothesu is an unknown quantity at this point
105? im pretty sure a stock 1.7 non vtec is 115. i could be wrong. the vtec is 127 stock
Old Oct 23, 2007
AmbulanceMonkee's Avatar
i think it's about 115 at the crank, and 105 at the wheels, if you have a MT. Prolly slightly less with auto.
Old Oct 23, 2007
andyman97's Avatar
Turbo Guru
More like 90 at the wheels. No, there is absolutely no vtec on a non vtec engine. Vtec engages a separate lobe/set of lobes. You have 4 lobes per cylinder on the camshaft of a non vtec engine. Period. There is no variation in your valve lift whatsoever.
Old Oct 23, 2007
awesome. that makes me feel even better about my car.
Old Oct 23, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
VTEC /iVTEC also have solonoids to engage this dont they?
cuz even on my iVTEC it has x3 soloids for the system
Old Oct 23, 2007
on the d17, think there is only one. on an ivtec, there should be more, as it is changing both the intake, and exhaust valving. on the d17, it's only the exhaust changing.
Old Oct 23, 2007
OK ok sweet.
90 hp... any idea how much torque? I'm sure it's rediculously impressive...
I have a m/t
Old Oct 23, 2007
FGCOUPE's Avatar
http://civicnation.12.forumer.com/viewtopic.php?t=35
im assuming you have the D17A1?
if so its rated at 115/110 Hp/Tq
Old Oct 23, 2007
DsevenEm2's Avatar
This is Myspace
yea but thats at the crank..so you're never going to feel any of that power, torque will also just be lower than the hp... it really doesnt matter how much.. but ur friend doesnt know wat hes talking about.. i was right.
Old Oct 23, 2007
FGCOUPE's Avatar
i can almost guarantee that any car on a Dyno will produce numbers differerent then the OEM specs.
Old Oct 23, 2007
DsevenEm2's Avatar
This is Myspace
um...duh? all oem specs on engine hp/tq are done at the crank.. dynos dont measure at the crank, they take it from the wheels.. ::doh::
Old Oct 23, 2007
FGCOUPE's Avatar
Hub dyno, mustang Dyno, etc...all different too....
mustangs read the lowest HP ratings
Old Oct 24, 2007
Well like I said I thought this kid was a tool. He and a few other guys were talkin smack about his car, their car, etc and who's fastest. I was just like "I'll pass more gas stations than you guys." And then they proceeded to laugh and then asked about my car.
My mods include: Blue light on dash for fire department. Dual horn setup to get rid of the weak Honda horn. Other than that I just do maintenance and keep it as clean as I can.
Thanks for the info guys!
Old Oct 24, 2007
Nighthawk7thGen's Avatar
Nighthawk7thGen is an unknown quantity at this point
Oh hey,
as far as engine life goes...i bought mine with 81K on it in August 2006...Ive got 101500 on it as of today...
Those miles I personally put on the car Ive got to say....have been some hard freekin miles. Im putting it thru hell...and I havent noticed any wince of pain from it yet.
So...heres food for thought....
"It's A Honda"
Haha!
Old Oct 25, 2007
Okay, I got mine with 55k I'm at 65k now and still doin great. I am about 80% gentle 20% hard on it, I drive pretty granny most of the time but i do go WOT sometimes and chirp second gear, ha. I do fully synthetic changes every 5k so far and I figure the less I mod on the car and more i maintain it and keep it normal the better.
Some of the "CB7" accords go 200k plus no prob so I don't doubt me getting at least 100-150k out of this civic.
thanks
Old Oct 26, 2007
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
116k here...getting input shaft bearing replaced tomorrow cause im an idiot and shift hard as hell ALL the time. 28mpg city, 36 highway cruising at 65. car has no leaks or anything of that nature, everything underneath is nice and dry...my friend just bought one with 150k on it and it drives better than his old altima that had 60k and old saturn that had 112k
GL
Dani1993
Jul 24, 2015 09:02 AM
cizsak
Jul 21, 2015 03:39 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
EliseKStewart
Jul 15, 2015 11:11 AM
NoobyKid
Jul 13, 2015 07:53 AM
