need help with e-manage blue
Old Aug 29, 2007
zexpoweredem2's Avatar
zexpoweredem2 will become famous soon enough
I have a 2003 honda civic ex that i put a turbo on everything went on ok, but when i got to the electrical part things went bad fast.
I connected the e-manage up with a plug and play harness from boomslang, then i went to start the car and it would not start. When i would turn the key to the position where you can hear the fuel pump kick on it would blow the fuse for the ignition coil. But when the car is on the factory ecu it will start just fine.
I called dezod and talked to paul and he told me that i needed to set the jumpers up, which i didn't do the first time he said that could be the reason that it was blowing the fuse. i set the jumpers up but it still won't start the car.
I checked the harness for any places in the harness that might be bad ( cut in the wire, etc.) i could not see any. i called boomslag up and they told me to send the harness back to them and they would check it out and send it back, does anyone else know of anything that it might be causing this to happen, i need to get it tuned but i'm not able to do so with out the e-manage working.
Has anyone heard of the e-manage box going bad, i know for a fact that i have the jumpers set the way they are suppose to be, i got them off of dezod.com.
I was looking through the e-manage support tool manual and it said that if the car does not start to set two of the jumpers a different setting, so i did just that, i installed everything back in and went to start the car, my father inlaw was standing out side of the car and i was inside with my head under the dash so i could see if the fuse blew or not right away, as soon as i turned the car to the section where you can hear the fuel pump kick on there was a huge bang sounded like a gun my father inlaw said it sounded like it came from the engine but to me it was all around, i disconnected eeverything and the car started right up on the factory ecu, i still have no idea what might have made the bang noise, does anyone else.
Please any help.Thanks in advance
Matt
Old Aug 31, 2007
dezod's Avatar
7thgen Power Maker
Re: need help with e-manage blue
Matt...note that there are 2 rotary settings that work on the D17. 4-8-E and 4-8-C. No one knows the line that is crossed for one to work better than the other, but they do. So you might want to try that.....
Old Sep 1, 2007
thanks paul, i sent the harness back to boomslang and there checking it out to make sure that they did not cross any of the wires.
When i talked to boomslang they said to set the rotory settings to 4-8-b and the car did the same thing, then that's when i sent the harness off to them.
I called greddy and talked to chris he told me that the rotory setting that i have set on b is only to control the air flow? And that it would not blow the fuse, he told me that it had to be the harness.
When the harness comes back i will set the rotory settings up to what you said and see if it will start ( i have been praying that it will) if it does not work i will try to wire the harness in. i just have to find out where the wires conect to the factory harness.
If anyone knows of a chart i would love you all for that, i just hope that i get it fixed soon, i have been driving my honda passport for the two weeks the car has been down and it costs a ton of money to fill up compared to the civic, $45.00 and it only lasts 300 miles.
Well thanks to everyone
raymondxcho
Sep 29, 2015 09:00 PM
sccarally
Texas
Sep 27, 2015 03:33 PM
68camerors
Sep 24, 2015 06:18 PM
MamaBear2015
Sep 4, 2015 09:04 PM
