After-Market 07 Civic Two Door Fog Light Question
Rep Power: 0 After-Market 07 Civic Two Door Fog Light Question
Just installed a set of after-market fog lights on the car. They look great.
The only part left is the interior harness and I have a couple of questions if anyone can help.
There are seven connectors on the harness. I have attached a picture.
1. Brown plug which connects to the harness going to the fog lights.
2. Black plug to the relay.
3. Black wire to ground.
4. Green plug to fog light switch.
5. Small male blue six pin plug which goes to the fuse panel.
6. Larger female blue six pin which I believe is extra. ????
7. White/red wire which I believe goes into white fuse panel plug.????
Is this correct or should there be more wires. No instructions came with the the kit, and the ones from the dealer seem to have more loose ones.
I was hoping someone could confirm this is right before I plug it in. I don't need to short something out.
Appreciate it.
Appreciate it.
Re: After-Market 07 Civic Two Door Fog Light Question
Goto http://www.hondaautomotiveparts.com/ you can get the instructions to install this unit from there under the accessories page.
SSMatey
04-13-2015 06:09 PM
