8th Gen 2006 - 2011.
Blower relay location
Old Feb 13, 2019
christian_cjo's Avatar
christian_cjo is an unknown quantity at this point
Hi,
I have an HONDA CIVIC Hatchback VIII 2009 and blower motor doesnt work
Have tested blower motor and transistor out of the car and they are fine
Both Fuses 40&10 amp are ok.
Trying to locate blower relay but I can not find it, suggestions where to look...
/Christian
Old Feb 13, 2019
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: Blower relay location
How did you test the transistor? Is power being supplied to the blower?
Old Feb 15, 2019
Did test the transistor on my work bench, se image
Old Feb 15, 2019
Bench ?? Do you know what to look for? Most common failures?
I only test components such as these LIVE and in-circuit. (I also have plenty of spare and repaired parts to test with if the voltmeter tests are not quick enough)
If the blower fan motor does not run, something is amiss.
What did YOUR testing entail?
It's a simple electric motor, it must have both power and ground in order to run.
Is the blower motor missing power?
Is the blower motor missing ground?
(your pic seems to indicate +12v is found on both sides of the fan motor??? Is that right? If so, it would appear the power transistor is not able to control the ground circuit to the fan motor) Check forum for ways to repair the transistor as a test
Schlef
Oct 8, 2017 07:44 PM
mikey1
Dec 6, 2016 08:21 AM
Stopka
19
Sep 23, 2016 12:33 PM
RotorBeav15
27
Jun 19, 2016 11:05 AM
DouglasTheGreat
May 27, 2015 11:23 PM
