8th Gen 2006 - 2011.
2008 honda civic horn
Old May 1, 2018
Chabi's Avatar
Chabi is an unknown quantity at this point
HELP NEEDED
My 2008 honda civic horn not working every time i click horn i can hear sound under the desk i have researched and find that it might be relay but the problem is dont have any knowledge about car can anyone please help the where is the relay under the desk which number it is. Waiting for your answer
Old May 1, 2018
Colin42's Avatar
Re: 2008 honda civic horn
If you can hear the relay under the dash than its probably ok. The horn itself might be dead, it's behind the front bumper.
Old May 1, 2018
Chabi's Avatar
What do i have to do next to fixed it buy new horn or i can change relay?
Old May 1, 2018
Colin42's Avatar
You need to test to see if the horn gets 12 volts when the horn button is pressed
Old May 2, 2018
Like colin said, if you hear a click, that's the sound of your horn relay switching over. Clicking is a good sound, with regards to the relay
If you wanna test the horn itself, you just gotta run some wires directly from the battery (or any other 12VDC power source) to the pins on the horn. If it makes sound, there's some disconnect between the relay and the horn (deteriorated wiring, faulty connections, etc). If no sound, horn is FUBAR and you gotta replace it.
Old May 2, 2018
Chabi's Avatar
So that mean relay is good I don’t have to change it is that right??
Old May 2, 2018
Colin42's Avatar
Should be
Test, don't guess.
Old May 2, 2018
Chabi's Avatar
I dont know where to find relay what number relay is it.
Old May 2, 2018
CraigW's Avatar
Your relay is now integrated into the under dash fuse box..... and, not a replaceable discreet part.
astudent
Apr 8, 2011 08:17 AM
Spartanic
Jun 30, 2009 07:34 PM
RRB
Sep 13, 2008 08:26 AM
WiseRabbitSays
Mid Atlantic
16
May 6, 2008 08:00 AM
