8th Gen 2006 - 2011.
Maintenance: Service Due Soon B123
Old Apr 30, 2018
Aloupha's Avatar
Aloupha is an unknown quantity at this point
Hello,
So, I have my first maintenance due on my 2015 Honda Civic (just reached 50k on it), and I have a few questions. According to the manual, Code B123 means the following:
Code B:
  • Replace engine oil and oil filter
  • Inspect front and rear brakes/service as necessary
  • Check parking brake adjustment
  • Inspect tie rod ends, steering gearbox, and boots
  • Inspect suspension components
  • Inspect driveshaft boots
  • Inspect brake hoses and lines (Including ABS/VSA)
  • Inspect all fluid levels and condition of fluids
  • Inspect exhaust system#
  • Inspect fuel lines and connections#
Code 1:
  • Rotate tires
Code 2:
  • Replace air cleaner element
  • Replace dust and pollen filter
  • Inspect drive belt
Code 3:
  • Replace transmission fluid
Is it necessary to do all the things mentioned above?
Is this a job I can trust Pepboys to do?
What's the reasonable price range should I expect?
Thanks
Old Apr 30, 2018
CraigW's Avatar
Re: Maintenance: Service Due Soon B123
Pepboys are not going to have the correct CVT fluid you will need.
Take it to the Honda dealer.
Old Apr 30, 2018
Oil change
Rotate
Filter set
Trans fluid service
Plus the basic routine inspections.
As suggested, just take it to your local Honda dealership, for at least the trans service (assuming CVT trans). Nobody else will have the correct CVT trans fluid on hand unless they deal with these on a daily basis.
Old Apr 30, 2018
Aloupha's Avatar
A local Honda dealer quoted me $350 for those outlined above. Does this sound reasonable?
Old Apr 30, 2018
How much can you DIY?
Can you change oil? Juggle tires?
Anyone should be able to DIY the two filters.
Old May 1, 2018
Aloupha's Avatar
I have never changed my oil before or do any work other than installing new head unit, manual to power window conversion (including wiring), installing backup camera (wiring included), etc... but I watched the videos for changing the oil, filters, and trans fluid, and I am pretty sure I could do those if I put the time in. I know I could rotate the tires.
There are a few more things on the list I think I could do if I put myself to it. I am not sure that I have the time though, and I am missing a few tools (which I could easily get).
I do have extended warranty on this car, and it will absorb some of that 350 cost, but I wanted to know if the estimate is justified.
btw, yes it is a CVT transmission. I forgot to answer that.
Old May 1, 2018
Sounds like you're well on your way to saving $250
No, it won't. That's only for repairs, not maintenance, unless you got some service deal.
350 would be high at my local dealer, but might be normal in a big city market
Old May 2, 2018
Aloupha's Avatar
I got the local dealer for details of the cost, and here it is:
Code B - Oil Change - $50
Code 1 - Tire Rotation -> 21.95
Code 2
  • Engine Air Filter --> $45
  • Cabin Air Filter --> $65
Code 3 - Transmission drain --> $135
I am not spending 120 bucks to replace those filters. I'll let them do the tire rotation, oil change, and trans.
As for the air filters, is there anything specific I need to know? Do I need to get them from the dealership? What's your recommendation on what I should get?
Thanks
Old May 2, 2018
CraigW's Avatar
I bought a set of 3rd party filters for the 2010 local for about $40. Then a bit later, a set for the 2013 OEM online, and was virtually the same price shipped to my door for Honda parts.
Old May 2, 2018
Aloupha's Avatar
Are these okay?
Genuine Honda 17220-R1A-A01 Air Cleaner Element Assembly Genuine Honda 17220-R1A-A01 Air Cleaner Element Assembly
3 Pack - EPAuto CP134 (CF10134) Honda & Acura Premium Cabin Air Filter includes Activated Carbon 3 Pack - EPAuto CP134 (CF10134) Honda & Acura Premium Cabin Air Filter includes Activated Carbon
I have allergies, so I need a good cabin filter
Old May 2, 2018
CraigW's Avatar
Engine air states OEM..... but, talk is cheap.
3 cabins for $20 is a very low cost.
Roll the dice, and find out.
Old May 2, 2018
Aloupha's Avatar
I ended up paying 250 for this, excluding the air filters. They recommended that I replaced the break fluid for 115, but I declined.
Old May 2, 2018
Brake fluid service every 3 years. (it's in your owners manual)
IMO it's a pretty easy DIY
Old May 2, 2018
Aloupha's Avatar
They said it could wait till the next oil change. I thought it would be easy to DYI it,, and that's why I didn't get it done.
big2000dave
Jun 14, 2009 11:20 AM
SlvrLx26
Oct 17, 2004 09:44 PM
nitehawk
Oct 25, 2003 03:24 PM
eckocivic
15
Jul 27, 2003 05:12 PM
