8th Gen 2006 - 2011.
2008 Civic - DRL indicator on panel is off?
Old 12-12-2016
ZillaG's Avatar
ZillaG is an unknown quantity at this point
Question 2008 Civic - DRL indicator on panel is off?
The DRLs on my wife's 2008 Civic work, that is, they come on. However, the idiot light on the equipment panel that indicates they are activated is off. What could be the problem? Fuse burned out? Which fuse? Thanks.
ZillaG is offline
Old 12-12-2016
Re: 2008 Civic - DRL indicator on panel is off?
The idiot light that says DRL should NOT be on.
It is a warning light, it comes on if one/both of the high beam bulbs is burned out.
The only thing you should see on the dash when the DRLs are on, is the blue high beam indicator glowing dimly.
I think the owners manual can explain this further.
ezone is offline
Old 12-13-2016
CraigW's Avatar
IIRC, certain markets use 2 indicators. Like the fog symbol upside down or similar.
Not likely any fuse, and also likely it uses LED to illuminate,
CraigW is offline
