New to CVT
New to CVT
Hey Everyone, I just leased a 2015 Civic LX back in december. Every vehicle i've ever owned before has either been a regular automatic or a 5 speed so the CVT transmission is new to me. My question is pertaining to when it's cold out. I live in Northeast Ohio and now that winter is in full swing, when i go to start the car up in the mornings, the transmission seems to take a second or two when i shift into Drive or Reverse. It seems like a little bit of delay. When warmed up or above, say 20 degrees, it does not do it anymore. Is this a characteristic of the transmission type?
Thank you all,
Justin
Thank you all,
Justin
Re: New to CVT
I find this can happen after a startup even when the engine is still warm.
(I'm one that slaps the shifter into drive as soon as the engine is running)
If you try to mat the gas pedal before the trans has fully engaged, the computer won't let the engine rev up much either.
Re: New to CVT
[QUOTE=CraigW;4701647 (it was with 5AT regardless of temp when going into D)[/QUOTE]
What do you mean with the 5AT? Im noticing this mostly when it is really cold out. When it's warmer or the car is already slightly warmed up, the delay is minimal. I'm not really too worried or bothered by it, I just wanted to make sure it's not out of the ordinary. I guess it's good that the computer electronically controls it so that it saves the transmissions life a little bit.
Jusitn
Jusitn
Re: New to CVT
5 (speed) AT (automatic transmission)
I asked about the delay a while back, and was told the conventional AT system selects 2nd, and then 1st when first shifted into D each time. So....just got into habit that after placed in D to wait 1-2 seconds before accelerating.
Your system may have similarities & ezone drives all different models/configurations often and has seen the same thing.
Re: New to CVT
Ahhh i didn't put the two together with 5AT! This makes sense with the way that CVT systems work. Starting off in 2nd gear in a manual transmission is usually never a big deal (unless on a hill) so I could see how the process would be the same.
Re: New to CVT
Thank you all,
Justin
Thank you all,
Justin
..After the lease let it go. I have a 2004 with a CVT. ..after 150k, trans went out. All the fuel savings that the CVT is supposed to save me, just went out the door. A rebuilt CVT trans cost me $2600.
No more CVT for me.
Re: New to CVT
Well I was always skeptical about the CVT but on most cars anymore, it's either CVT for the AT or manual and my fiance cant drive manual so we can see where this is going... I had an 06 Mazda 3 MT before the civic but I was buried in negative equity and couldnt afford the vehicle I really wanted ('16 Silverado 4x4) so I decided to play it smart and trade in and lease the civic for a few years then I'll be more financially in place to buy the truck. So far after about 2k miles, I'm really enjoying the civic so far and besides being pretty slow, it's a great car to have. But I doubt I go with another CVT after this, no matter what I buy.
Re: New to CVT
Re: New to CVT
Maintained, oh yes as I change the CVT trans with the spec Honda fluid every 25 k.
After 70kthe trans will have a delay in responding as the chains that make up the trans gets stretch by then. I compare it to a bicycle chain.
As I mentioned, it sounds good but my experience is that it will not last. ..when the CVT first came out, one of my friends Civic CVT only lasted 48k..
Now show me a regular trans that will fail that soon. Oh, my friends Civic, Honda paid for the trans and he paid for labor.
Re: New to CVT
^^^ You certainly went above and beyond then. Good info!!
Every time after seeing the theory on CVT, I can only shake my head.
Part of the reason for grabbing a 2013 5AT recently.
Re: New to CVT
Re: New to CVT
I have a 2014 Civic and just noticed in the owners manual to have the cvt fluid checked monthly by the dealer. This has to be a mistake. I looked for a dipstick on the tranny and found the rubber plug. There is no rod into the reservoir to check anything.
Is this some type of ripoff, or what don't I understand.
Ralph
Ralph
Re: New to CVT
Ralph
Ralph
It is no mistake, but once a month is probably overkill IMO unless you are having issues....
Any shop should charge fees for their time spent checking it....and unless you are at a dealership there's little chance of anyone having the correct fluid on hand if it happens to be needed.
The reasons for a dealer checking it are several....
the fluid level is checked using a plug on the side of the transmission, and is not intended to be checked by the user/owner.
Correct fluid level is critical for proper operation and long life. Fluid level changes with temperature, so the fluid should be checked at the temperature specified in the service manual. If you check it at a wrong temp, the fluid level could easily be incorrect.
There is also a shift sequence specified before checking fluid level.
It takes a specialized fluid (HCF-2), you can cause serious problems if you try to add the previous Honda CVT fluid (still in use on some other models) or anything from your garage or parts store. The HCF-2 fluid has only been in use since the 2013 Accord new CVT introduction.
(I've not seen any claimed compatible fluid in my local parts store the last time I was in there browsing, and so-called "universal" fluid is anything but.)
Even though your manual says to use a dealership, beware there are probably many people in any given dealer shop that don't know really how to check it correctly (usually the low paid oil changers and beginners)....because it is not stupid simple.
Most just run with the assumption that if there is no fluid leakage then the fluid is probably still full....which is usually a pretty realistic assumption IMO
At our shop we still suggest trans and CVT fluid service every 30,000 miles.
HTH
sbi
Sep 2, 2015 07:44 AM
KamikazeKunze
Aug 30, 2015 10:38 AM
Doesn't sound like it of course
