8th Gen 2006 - 2011.
How to recover your Radio Code.
Old Jan 11, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Exclamation How to recover your Radio Code.
There is no longer anybody able to pull codes for you. What you need to do is look throughout your car for a sticker that has it..this could be in the glove box, inside the fuse box or several other places..if you cannot locate it then you will need to
Retrieve your radio serial number by
holding down the #1 and #6, turn the radio ON, and the serial number is displayed in 2 parts. Only works after the radio says CODe on the display.
(or should be on the back or your radio)
Record your vehicle Identification number.
Once you have that then you need to visit.. https://radio-navicode.honda.com/
If you are not the one who bought the car from the dealer and have not updated your information you should do so. Visit http://www.ahm-ownerlink.com/ But for now lets continue.
since you cannot fill out all the required info then all you need to do is call
1-800-999-1009
With all your info.
This will take all of 5 minutes and all of YOUR information will be recorded with Honda. This is also FREE you should not have to pay for your code..
Old Jan 11, 2012
MindBomber's Avatar
Live for the Twisties
Re: How to recover your Radio Code.
haha I think this is our third, how to find your radio code thread..
the people never learn..
Old Jan 11, 2012
2002ExCivic's Avatar
2002ExCivic has a spectacular aura about2002ExCivic has a spectacular aura about
Someone should remove the Sticky where you request and Sticky this instead.
Old Jan 11, 2012
Since 2000 or 2001, you can hold down the #1 and #6, turn the radio ON, and the serial number is displayed in 2 parts. Only works after the radio says CODe on the display.
Works on most in those early years, works on all since about 02.
Those instructions are also on the Honda radio code site. https://radio-navicode.honda.com/
Acura has this site https://radio-navicode.acura.com/
Edit: dangit, I changed the text but the link didn't change....redo.
Old Jan 12, 2012
Gunner's Avatar
^thanks for adding that..I will input it to the top..
Old Jan 12, 2012
MindBomber's Avatar
Okay, so..
This thread has been stuck, the other thread has been unstuck and locked on a trial basis. The large thread has been allowed to remain open, because it contains the majority of radio code requests; however annoying seeing it bumped can become, it's better than constant new requests. If new threads for radio codes begin popping up again, I will reverse the changes to the big thread.
Old Jan 20, 2012
Gunner's Avatar
^ CALL HONDA with the number above, Its an 800 number..not sure if you will still be charged long distance but call them and they will help you..
Old Jan 30, 2012
Gunner's Avatar
No Problem..everything needed is posted above..
Old Feb 21, 2012
Streetwize86's Avatar
Streetwize86 is an unknown quantity at this point
I was lucky enough to have the Number written on the dash pannel. The dealership is crazy for the cost of a simple code number
Old Apr 18, 2012
There are many ways for an owner to obtain the radio code for themselves.
Sticker/card/books, Honda website, the customer service number, etc.
If one can't figure out how to do it for themselves, then they should be prepared to pay a fee for the service.
Proprietary information doesn't have to be free.
Old Mar 13, 2013
Gunner's Avatar
^ Read the original post... that is about all the help anyone can give you.
Old Mar 20, 2013
hioto's Avatar
hioto is an unknown quantity at this point
I can help.
email me @ shane.lee@torontohonda.com
provide serial number or U&L code.
Im not online on this forum everyday but PM works as well and it will send a notification to my phone.
I hope im not stepping on anyones toes here, but i joined this forum to help and if I can I will.
Old Mar 24, 2013
jdavid621's Avatar
jdavid621 is an unknown quantity at this point
Originally Posted by hioto
I can help.
Hola amigos chapines, puedo ayudarles a conseguir su código, de igual forma solo escríbanme, jdavid_mazariegos21@yahoo.com, solo puedo conseguir los códigos si estás en Guatemala, saludos
Old Mar 25, 2013
Gunner's Avatar
^ in english, this means
I can help you get your code, just write me equally, jdavid_mazariegos21@yahoo.com, I can only get the code if you are in Guatemala, Greetings
Old Apr 30, 2013
Gunner's Avatar
PLEASE!! Read the Original post. I think their may be a person or two that may still be willing to look but its rare(and partially illegal). So please follow the above posts.
Old May 1, 2013
hioto's Avatar
I can get codes. VIA email only please.
Old May 2, 2013
Gunner's Avatar
^i will start pointing people in that direction then. Thanks.
Old May 31, 2013
jedema's Avatar
jedema is an unknown quantity at this point
Wow... read the op, then called the number with my info...
Who knew that it was so hard to read... That number worked like a champ!
Old Oct 13, 2013
smallac's Avatar
smallac is an unknown quantity at this point
I just bought a used 2012 Honda Civic with no radio code visible. I checked the glove compartment, all the stickers around all the door jambs, the trunk, etc. All I can find are a bunch of VIN stickers and the ones for the tires and the vehicle weight.
This Civic's radio has no display of its own. It uses the car's display on the dash. I cannot get the "code" text to display, and tried depressing the 1 and 6 while powering up. There is not a hint of a response.
The car and radio are working fine, but eventually, I'll need a battery. Is it possible that this radio does not have that function. This is an LX.
Old Oct 13, 2013
(USA) 2012 LX does not have a locking radio.
Old Oct 29, 2013
kingrat's Avatar
kingrat is an unknown quantity at this point
I had no sticker in the glove box for my 2002 civic but the door had a code and I entered that and it is working now!
Thanks
Old Nov 1, 2013
Originally Posted by janus27k
Hello
I have tried different approachs to find my radio code and none have worked.
Twitter cost service
1-800 phone call
Honda website
So, i came here asking for help
Honda civic ex 2007
Serial heb23009741 4 digit code
If anybody can help me.
My thanks in advance
If this is a radio try 66411
If this is a Navigation unit, try 3504
Now post your credit card numbers so I can collect my fee!
Old Nov 1, 2013
Originally Posted by CRsaucedo
Hi,
Could you please help me to get the code for my radio. I bought my car in a sale (copart) and i dont have the zip code and phone number for the first buyer. I'm in Guatemala city.
Honda Civic 2008
sn # 26066519
vin # 2HGFA16538h317781
THANK YOU
Originally Posted by Ernimex
Gearbox please help me with the code of my radio
Vin# 2hgfg11858h901423
Serial# 40171796
Originally Posted by bigi2006
someone could help me be grateful for life, I have the radio code and I live in Guatemala, if someone can help me here is the info of my CIVIC.
VIN: 1HGES26793L014922
Radio Series: U 2829 L 4603
other information
P / N 39101-S5A-A610-M1
Ref.No. MF721AA
CMH28294603C
many Thanks
Originally Posted by norvertmiranda
hello , i need a heelp for civic coupe 2008 the radio serial number is 40171789
please help me
Originally Posted by sweet_ella
Hello
I also have a similar problem and I needhelp%u2026 I bought a home used Honda civic and the radio is nowdemanding for a code after I had some issues with the battery.
The serial number is 26029237
The vin is 2HGFA1F34AH515726
Serial# 40110925 Please erhuezo@hotmail.com
Serial# 22002979 Please advise me hernaoehernaoe@yahoo.com
Serial# 26931289 Please mariagne_samudio@hotmail.com
Honda Civic 2004 r. serial number U3000 L3205 , VIN: SHHEU87704U304150
Thank you very much in advanced.
MY EMAIL :mikolajjgn@wp.pl
Honda Civic 2005 r. serial number U3001 L2655 , VIN: SHHEP43905U300220
my email: svet_21@abv.bg
Honda Civic 2009
S/N: 40038105
VIN: 2HGFA55569H707705
my email: java434@gmail.com
Honda Civic 2008
S/N: 26043807
VIN: 1HGFA16568L038912
Thank you very much.
my email: francisco.newball@gmail.com
Honda Civic 2007
S/N: 40052303
VIN: 2HGFG12647H518214
my email: rblanco@sc.gob.sv
Originally Posted by ELEE0118
Hi Gearbox,
Can you please help me with the readio code for my honda civic 2009
The info is:
VIN: 2HGFA16529H348683
SN: 22087199
email: ericklee@yahoo.com
Many thanks for your support.
Best Regards,
Good god. Many are not even capable of reading usernames?!?
Gearbox have not been around for a while. not even in this thread.
buy glasses, people, or you will not even be able to read the serial numbers.
dumb and unable to read... whats the point in replying if you cannot even read?
Old Jan 6, 2014
SlowEJ8's Avatar
SlowEJ8 is an unknown quantity at this point
interesting read
Old Apr 10, 2014
GolNat's Avatar
Prelude Owner
S/N 40001242
vin 2HGFG21576H700700
Call this number
1-800-999-1009
With your serial number and vin handy.
ricer_em2
May 11, 2016 08:09 PM
Bruce2
Sep 27, 2015 08:45 PM
Mc7602
Sep 17, 2015 02:01 PM
jpat21
Sep 3, 2015 11:32 PM
