Where I'm at...
Where I'm at...
I've just put 62,000 miles on my 2007 automatic civic. It'd be a lot less, but my job now has me putting 17,000 a year on my baby.
I've been religious about changing the oil and rotating the tires, however I've gotten conflicting statements about fuel pump and transmission service.
What else should I REALLY get done at 62,000?
Thank you!
Thank you!
Kenny the Ricer
Re: Where I'm at...
62K is not a huge amount for a 6 year car. In fact, it's quite low.
That's only about 10K/yr.
There's nothing much you need to have done at this time, probably just your fluids and spark plugs.
Transmission fluid, Radiator fluid, Power Steering fluid, Brake flush.
I would inspect your brakes and rotors while down there.
Re: Where I'm at...
Re: Where I'm at...
Kenny the Ricer
Re: Where I'm at...
Re: Where I'm at...
ATF every 30k max. I would do it more often in my own. (Experience makes me recommend far more than the manual or maint minder says.)
ATF DW-1 from Honda.
Drain and fill, about 3 quarts at a time.
The rest of the maintenances you can just do as the maint minder tells you (except for time-based services). See the owners manual.
Plugs, 100k or more. (They really will go 200k or more without a problem unless the engine fouls them.)
Coolant at 5 years, long life blue from Honda
Brake fluid at 3 years, DOT 3
When the air filter gets dirty, change the cabin filter too.
TOP TIER GAS should completely eliminate the need for fuel system additives.
http://www.toptiergas.com/retailers.html
Fuel pump is damn near bulletproof. These ain't Chevys.
Kenny the Ricer
Re: Where I'm at...
I changed mine out at 40K and it was dirty as hell.
Re: Where I'm at...
Owners manual says 100K for ATF change for 7th gen
I do my moms ATF every other oil change. She has an 02 Accord, it is known for differential bearing problems. So far, so good.
Did the ATF in my 12 Civic along with its 5000 mile oil change.
Kenny the Ricer
Re: Where I'm at...
Not absolutely necessary.
But recommended.
When I did it, I just drained the stuff in the rad, I didn't even drain the block.
The rad is pretty easy, just a little plastic tab under the front bumper.
Drain and fill.
check and replace your filters if necessary.
But recommended.
Drain and fill.
Re: Where I'm at...
....because the additives that prevent corrosion break down.
also even though your mileage is low check for # of years in the maintenance minder (i.e timing belt is every 7 years on mine)
Re: Where I'm at...
The Honda Type 2 Coolant jug says 5 year/60,000 miles right on the label.
Much easier than every 2 years in the olden days of conventional coolants.
Re: Where I'm at...
You could get 2 gallons to be safe, but I don't think you'll need the second at all unless you try to drain the engine block too.
But you'd have it to top off the reservoir before oil changes so you KNOW what is in it is right.
I don't really pay attention because I don't have to buy the stuff ahead of time like you guys do, and there are always several partial jugs laying around the shop because we top off fluids during the oil changes.
HTH
carlos209
Jun 4, 2012 06:08 PM
Mad Dog Tannen
Jan 26, 2012 03:54 PM
