8th Gen 2006 - 2011.
Just changed 8th gen Auto Trans Filter
Old May 25, 2012
ubnpast's Avatar
ubnpast is on a distinguished road
Yes the automatics have an external trans filter as well, its about $27 from the dealer (part# 25430-PLR-003). I havent seen anything stating the intervals in which it should be replaced, but I figured for $27 it couldnt hurt, it looked pretty dirty to me (112k miles, original owner had a few trans fluid flush's done to keep it clean, in the stack of maintenance records).
This seems like a universal fit part from honda as its used on:
ACCORD 2D '03-06
ACCORD 2D '07
ACCORD 2D '08-11
ACCORD 4D '03-06
ACCORD 4D '07
ACCORD 4D '08-11
CIVIC 2D '01-04
CIVIC 2D '05
CIVIC 2D '06-'09
CIVIC 2D '10-11
CIVIC 4D '01-03
CIVIC 4D '04
CIVIC 4D '05
CIVIC 4D '06-08
CIVIC 4D '09
CIVIC 4D '10-11
CIVIC HYBRID '06-'11
CIVIC NGV '06-'11
CR-V '02-05
CR-V '06
CR-V '07-11
CR-Z '11
ELEMENT '03-06
ELEMENT '07-10
ELEMENT '11
FIT '07-08
FIT '09-11 (KA,KC,KX)
INSIGHT '10-'11
ODYSSEY '11
Old May 27, 2012
johng35's Avatar
johng35 is an unknown quantity at this point
Re: Just changed 8th gen Auto Trans Filter
Any tips on how to get at that thing ? That is my next weekend project.
Old May 27, 2012
ubnpast's Avatar
Remove the air cleaner assy (top cover, filter, 3 10mm bolts, Phillips band clamp and hose clamp) pull it all out if way lifting bottom portions rubber grommet over a nipple.
The Trans filter is held on with a 10mm bolt and a 2 part
clamp, 2 hose clamps must be removed as well as the 2 hoses connected to the filter, use some channel locks to twist the hose while it is still on the filter (to break them free, be careful that you dont chew up the hoses.
The lower hose and hose clamp can be accessed from under the car also.
Old May 27, 2012
mattandchris's Avatar
mattandchris is an unknown quantity at this point
Not having ever done this before, how long did the task take you to complete?
Old May 27, 2012
ubnpast's Avatar
Having never done it before you should plan on about 1 hour total time including the 10 minutes for drain and fill of the ATF (2.5 qts, please verify in your owners manual).
Once you become familiar you can do it in about half the time.
Old May 27, 2012
MindBomber's Avatar
Live for the Twisties
I had an argument with two dealership employees over the existence of this filter, I was right of course
Old Jun 6, 2012
UBNPAST...is it required/necessary to drain the transmission in order to change this part?
Old Jun 6, 2012
ubnpast's Avatar
I don't believe you have to but why filter dirty transmission fluid, I bought 2 cases of Honda dw1 atf (12 qts) @ $85 ea shipped. Change the atf also, it does get dirty pretty quick.
Old Jun 7, 2012
Ubnpast.........................tyvm
I sorta put the cart before the horse.
I did a drain and fill LAST week...and...TODAY I got my external transmission filter delivered from Majestic auto parts.
I was going to install that filter today and was hoping to hear that I didn't have to drain down the ATF fluid.
I expect some mess.........
Boy-o-boy, there is nothing to that little external filter. Consequently, I could see how it could get clogged so easily.
I think I will open it up the old one and take a look inside,once I get it on the work bench.
mattandchris; 2010 Civic LX; 30K miles
Old Jun 7, 2012
The filter is higher than the fluid level.
The only mess will be the fluid trapped within the filter and lines.
Use a tubing cutter if possible for a clean cut with no debris.
I wonder how much of the mess in the pics is from hacksawing the filter can.
HTH
Lt. Dan
May 13, 2015 12:42 PM
carid
Apr 30, 2015 07:00 AM
davidpaustin
Apr 29, 2015 02:23 PM
02Si
Dec 14, 2001 10:26 AM
CiViCPrAnInG2k1
Dec 6, 2001 12:14 PM
