8th Gen 2006 - 2011.
9th gen vs 8th gen differences?
Old Oct 29, 2011
lefty976's Avatar
lefty976 is an unknown quantity at this point
Hi fellow civic enthusiasts, I know that the 9th gen civic uses the same engine and tranny but it gets alot better gas mileage. Is this due to using 0w-20 motor oil and low rolling resistance tires? The 8th gen uses 5w-20, anyone using 0w-20 with better mpg?
Old Oct 29, 2011
MindBomber's Avatar
Live for the Twisties
Re: 9th gen vs 8th gen differences?
0w-20 does net better gas mileage, it's just a bit more expensive and harder to find than 5w-20 or at least was when the 8th gen was released. I've heard 0w has been recommended by Honda in Europe and Japan for a few years already.
Old Oct 29, 2011
lefty976's Avatar
Does anyone know what the oil change interval is if your using 0w-20 since it is fully synthetic vs 5w-20 which is conventional?
Old Oct 29, 2011
its mostly the fluids and tires, possibly a bit of aerodynamics. i have seen hybrid civics with a difference of 10mpg just on the tire choice. dw1 full syn atf, 0w20 full syn (or blend in some cases) motor oil. i have to admit im really skeptical about using these lower weight oils. 5w30 has always been the best all around oil even for a new honda. i suppose you can use a 0w30 if you live in colder climates, but going to a 20 hot weight is eventually gonna catch up to you. i remember at first they were only recommending this for hybrids, now its for all the civics and the engine designs have not changed between then and now.
Old Oct 29, 2011
lefty976's Avatar
Is anyone running 0w-20 in their 8th gen with any improvements in mpg?
runawaykinms
15
Mar 22, 2019 10:32 AM
John2009
Sep 10, 2015 09:53 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
dantheman42
Sep 4, 2015 01:10 PM
Bman2212
Sep 2, 2015 11:49 AM
