8th Gen 2006 - 2011.
new to civic
Old Jul 29, 2011
crasyasian's Avatar
crasyasian is an unknown quantity at this point
new to civic
*Flame suit on*
I am new to civic world, well hybrid world at that.
I own STi for years, but my son is 4 hours away one way, and gas is a killer.
So I went with a 2009 civic hybrid. I know I will get flame for this, but who care
so that out of the way, here are some question:
1. Will lowering the car change it MPG?
2. STi have lip to change the aero, to help, will it do the same for the civic?
3. Will changing wheel effect the MPG?
4. I was a suspension guy in STi world, would braces help or hurt MPG?
Any help would be kindly greatful, if you don't have anything nice to say,
please reframe from say anything at all.
Thank, T.
Old Jul 29, 2011
Re: new to civic
1. Why? maybe will change some of the underside flow of air, but don't know specifics.
2. Not really sure. Some of the miata guys cut out the lower side of the rear bumper so it does not dam the air in there.
3) Depend. Heavier wheels will have more mass, so they will tend to keep moving - lower MPH in city since you need to stop-and-go, while the highway gets better if you drive at constant speed. Same comments for the tire outer diameter - the larger the tire, the harder to accelerate and stop. They will prefer highway. Lathough i got around 42 MPG with 16" and slightly oversized tires but the 15" stock tires got up to 44 MPG in long drives, even if engine is running higher revs - weight is key, i guess.
4. Braces are not likely to help?
hondas will cut the gas if in a hill and throttle is off. use that wisely and don't mash the gas. Most MPG depends on driving. Also keep in mind that different than a STi, vics are momentum cars. The least you change the speed, the best.
Old Jul 29, 2011
crasyasian's Avatar
Re: new to civic
Well I want to get brace be cause of the handling,
Thank, for your input.
T
Old Jul 29, 2011
Re: new to civic
we gain more from sway bar selection than bracing. Although the 8th gen have more neutral handling than the 7th gen, from what i hear.
For example, the best for FWD is to hold the front strut towers, but if you look at it, where are the front strut towers? Under the windshield frame - enough metal in between them. they braced enough in my opinion. similar to the rear ones.
get to know more of the car before going crazy on the mods -some of them will not really improve much fer the cash spent.
keep in mind the comment that they are momentum cars, not a high powered ones.
Old Jul 29, 2011
MindBomber's Avatar
Live for the Twisties
Re: new to civic
1. I get better mileage than rated and my car is lowered, it stands to reason that it would improve aerodynamics slightly.
2. Yes, most civics have an air damn under the front bumper to improve aerodynamics, I think the 8th gen hybrid does.
3. Lighter, smaller wheel will improve mpg.
4. Hurt, because your adding unnecessary weight. If you want to improve the handling and continue to have a car that's somewhat fun to drive consider spending a bit on a rear sway bar.
Old Jul 29, 2011
Re: new to civic
lowering improves mpg because car is closer to the ground and less turbulence. same idea with adding lip kit, it will lower the car a bit from stock. wheels if they are lighter than stock and the same size or smaller will help mpg. but also bear in mind the aerodynamics. the honda rims im not sure how much they weigh, but they are very good at channeling air to the sides due to the closed design. open rims will reduce mpg. suspension mods dont really matter but the added weight will reduce mpg (prolly not enough to notice). tires will also affect mileage. the best are the lighter ones with low rolling resistance. but you sacrifice some ride comfort and handling. if you drive mostly freeway, then you want to build the car more for aero.
Old Jul 29, 2011
crasyasian's Avatar
Re: new to civic
Thank for your input
It really helping me.
jonavin
73
Oct 4, 2004 07:18 PM
locozoko
Apr 6, 2002 09:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
