8th Gen 2006 - 2011.
buying a 2008 civic si
Old 06-24-2011
cjjackson2400's Avatar
cjjackson2400 is an unknown quantity at this point
Are there any known problems with this year and model? Im new to honda I've always had jeeps..17k miles
cjjackson2400 is offline
Old 06-30-2011
08EX's Avatar
08EX is an unknown quantity at this point
Re: buying a 2008 civic si
Grinding going into 3rd gear, covered under warranty if you can convince the dealer you have the problem.
Poor AC performance in stop-and-go driving in very hot weather. No known cure, but some report theirs works fine. Some may be due to low charge, expansion valve issues, leaks, etc.
Road debris putting holes in the AC condenser. Fix by putting a screen behind the lower grill opening.
Sunvisors splitting at the seam. Should be covered under warranty or "goodwill" repair.
The Si needs premium gas. Supposedly you can run regular if you baby it.
08EX is offline
Old 07-01-2011
Budahhead's Avatar
Budahhead is an unknown quantity at this point
Yep, my 06 Si has those problems. I find triple clutching will help going into 3rd gear. Reverse was a problem for me too. put the clutch in, rev and go into reverse, should be fine. They are good cars, but be careful for 3rd and reverse.
Budahhead is offline
vtec92
05-04-2017 03:20 AM
usajags84
05-10-2015 08:11 AM
bsmiley
04-27-2015 01:27 PM
inarschenk
South
04-18-2015 04:29 PM
mugenca
04-16-2015 12:15 AM
Quick Reply: buying a 2008 civic si
