8th Gen 2006 - 2011.
Accessory belt replacement
Old 11-27-2010
speedy25's Avatar
speedy25 is an unknown quantity at this point
I'm not near my usual resources and need your guys help.
07 civic needs a fresh belt. I cant find the "typical" belt adjusters but did find a ~19mm hex near the center pulley, but I cant get it to move.
Anybody have some pointers for tension release so I can change the belt?
-SP
speedy25 is offline
Old 11-29-2010
speedy25's Avatar
Re: Accessory belt replacement
Either nobody is actually on here or noone has ever changed the belt!
--bump--
-SP
speedy25 is offline
Old 11-30-2010
Paul79UF's Avatar
Paul79UF is an unknown quantity at this point
I haven't changed the belt in a Civic yet.
But in most cars, find the tensioner pulley on the little chart in the engine bay or in the owner's manual.
Put a socket and long handled wrench on the nut on the tensioner pulley.
Usually you pull it towards the front of the car to release the tension on the belt. Then slip the belt off.
When putting on the new belt, remember that the ribbed side of the belt goes against the ribbed pulleys and the smooth side goes against smooth pulleys.
Make sure the belt is lined up properly on every pulley before starting the engine.
Paul79UF is offline
Old 11-30-2010
Paul79UF's Avatar
Oh and, if the tensioner or idler pulley(s) feel like they don't spin easily, replace them.
Some of the nuts holding the pulleys on will be reverse threaded (opposite of lefty loosey).
Paul79UF is offline
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
mattdoc
03-14-2017 12:10 PM
bsmiley
04-27-2015 01:27 PM
dano2005
04-14-2015 01:58 AM
thesushiboy
04-12-2015 02:54 AM
Quick Reply: Accessory belt replacement
