8th Gen 2006 - 2011.
Antifreeze Question
Old Sep 1, 2009
krazymatt's Avatar
krazymatt is an unknown quantity at this point
Antifreeze Question
My 08 Civic EX Coupe is now about to turn 20k miles. I was checking the antifreeze level last week and noticed it is a tad bit low. Is this normal? I noticed under the hood where the notice says to use Honda antifreeze. If not other antifreeze could damage the engine. What type of antifreeze do you all use? Thanks.....Matt
Old Sep 1, 2009
Re: Antifreeze Question
stick with honda brand
Old Sep 1, 2009
krazymatt's Avatar
Is it normal to lack at 20k miles or do I have a leak?
Old Sep 1, 2009
CraigW's Avatar
Agree with original fluids only.
Check the level when the engine is at temp ( it will have the most fluid in reservoir) and then check it hot each time. It will move a little up and down but not very much.
Maybe the dealer will give you a little added to the system. Not sure if the 8th gens still use the blue or not.
Old Sep 2, 2009
04 Honda Civic's Avatar
coolant evaporates eventually, summer just passed alot of heat more evaporation. Fill it up and if it goes low noticably quick u probably have a leak.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
