8th Gen 2006 - 2011.
2006 Civic Manual Transmission issue
Old Jan 19, 2009
Zsoltster's Avatar
Zsoltster is an unknown quantity at this point
I love the 8th gen civic - and the following is the only issue. So I have been experiencing something odd for about a month now (I actually noticed it last winter...but only for a few weeks then it stopped). Basically, when the car is turned on (cold engine) the meshing of the 1st gear at start is smooth and everything is fine, I release the clutch, and everything is smooth and perfect. But then after I drive for a bit (~15 min), the engagement of the 1st gear becomes a little jerky especially just as I'm about to release the clutch completely. The whole car vibrates a little, with it becoming more intense as time goes on. This happens when i try to start smoothly, letting go of the clutch slowly, and obviously giving the car enough gas so it's not stalling or over-revving. No matter what the rpm is (1000-3000) this still happens, at about the time i'm 80-90% off the clutch. The vibration is only momentary, but it gets intense enough to be felt. All the other gears shift smooth as butter! I just had an oil change and tire rotation last week, and it's still doing it.
Old Jan 19, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Re: 2006 Civic Manual Transmission issue
Could be transmission mount or clutch/flywheel. Had the same problem, went away so im just waiting til summer when I have more money to fix it.
Old Feb 27, 2009
04-Honda Civic's Avatar
04-Honda Civic is an unknown quantity at this point
Increase your idle up to around 1250 or 1300 and that should fix the problem. I had the same problem. I noticed if I drove in the night from a cold start, it drove fine till the engine heated up and idle dropped. It happened almost all the time. Also change your spark plugs to NGK Iridium!
Old Mar 19, 2009
sikassdrummer's Avatar
sikassdrummer is an unknown quantity at this point
I have 32k miles and have had no problems at all , yea they had to do a reflash on my drive by wire for rev hangs but since then its been great
i had that done at 7k and owned the car since 6k
2006 civic si asm
Xuhme
21
Aug 7, 2023 03:40 PM
bsmiley
Apr 27, 2015 01:27 PM
C6GrandSport
Apr 25, 2015 09:41 PM
Rinzlor
Apr 24, 2015 10:33 AM
cooldan1
Apr 23, 2015 10:49 AM
