Challenge for all DIY gurus (attn: Grey!): one-touch moonroof open/close
Old May 4, 2003
  #31
Ronin's Avatar
Ronin is an unknown quantity at this point
Yup, it definitely won't be as easy as Boilermaker said it would. That's why I said I would pay good money for this DIY if somebody can come up with all the instructions and wiring mods.
Old May 5, 2003
  #32
Grey's Avatar
DIY King
Originally posted by ohmysac
i dont have an ex...but is there an associated relay that supplies power to the sunroof...a capacitor/resistor/relay combination would do the trick...
edit: i just checked in my service manual..it seems there are two relays for the moonroof located somewhere above the headliner...one for opening it...one for closing it...it would be possible to press the switch for one or the other and add a capacitor and resistor to one side of the corresponding relay's coil to hold it open for a few seconds...the length of time would be dependent on what capacitance/resistance you go with...i'm not 100 percent..but i think this'll work..check with the guys at the http://www.the12volt.com
I think you've got it. It's all about adding two capacitors near the relays. That way they get charged up as soon as you press the button and they hold enough juice to allow the motors to operate until they close or open the moonroof. The only thing you'de have to get right is the capacitence. I don't know how much that motor draws? If it's small, then it wouldn't be much and you could do it without a problem. If it's a large value then it's kinda stupid to try and put in a large capacitor.
If it is a large value. then I guess you'de have to change the way the relay works. Instead of only closing the circuit when the button is depressed it would have to close the circuit for as long as the moonroof needs to open or close. Wait! That's it. Again, two capacitors are needed. One for closing and one for opening. Although this time all the charge they need to hold it the charge it takes to hold open the relay so that the circuit is closed. That's it! It should be easy enough to hook up.
I don't have a moonroof, so I can't experiment. Someone should try this though. They'll need to calculate how much current it takes to hold the relay open, or just experiment maybe??? Are there such things as variable capacitors? That would be nice. Then you could dial in the value you needed and use a multimeter to check how much longer the circuit is closed after the moonroof is open or closed. Yep. That's it. Anyone?
Old May 6, 2003
  #33
ohmysac's Avatar
ohmysac is an unknown quantity at this point
its funny how people without a moonroof are all over this idea anyways...this relay diagram is what i'm talking about...converting a pulsed to steady output...
http://www.the12volt.com/relays/page5.asp#pts
Old May 6, 2003
  #34
LiLaSiiAn8's Avatar
Wow! I just thought about that in the car on the way home. I'm not sure, but i think the Lexus IS300 has this feature. I hope someone tries out what Grey said! Thanx MR. DIY King. What if we wanted two auto window down buttons. Has anyone thought about that one yet? Useless pondering.. By the way, whats wrong with the switch for the blinkers?
Old May 7, 2003
  #35
dirtEsanchez's Avatar
Better Then God
dirtEsanchez is an unknown quantity at this point
I like my freinds Jetta when it comes to the moonroof. It is just a **** you turn and everything is done automatically...
Old May 7, 2003
  #36
Spazbitte's Avatar
Spazbitte is an unknown quantity at this point
Sorry to shoot you guys down. But I am going to school to be a electronics engineer and work in a shop as a electric tech. I did some talking with my boss and my teacher. The only real way to do this is to get a new relay (gate). Thats the braint that determines all the work. Using capicitors is only a temporary thing. Since they discharge they wouldnt stay high enough long enough for the thing to work. You would be smoking components with the proper current need to run the system. So if you wanted to go find a new logic gate and find out how to wire it. I would go that direction. Sounds like to much work for six seconds here or there.
Old May 7, 2003
  #37
Oishi's Avatar
Oishi is an unknown quantity at this point
just incorporate a 555 timer into the switch...monostable mode...
Old May 7, 2003
  #38
Oishi's Avatar
you'll still need to incorporate a switch to toggle back and forth for opening and closing...unless of course the polarities would switch since the window will go in a different direction...aughh...too much things that you want and not enough information for this...questions like
1)is the voltage for both motors (assuming there's two) the same polarities?
Old May 8, 2003
  #39
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Just go buy a DEI window automation kit (part #530t) and hook up half of it (only one "window"). automation gives you one touch up and down, so why not open and close your sunroof with it.
Old May 8, 2003
  #40
WhiteRabbit's Avatar
hjdfagjhdfafjkds
i wrote a really long post about this, then hit the wrong button. i am very saddened.
the jist of what i said was that the timer relay will work. but you end up damaging the motor long term as you continue to feed current to it for the fraction of a second it remains on even tho the roof is open all teh way.
designing a circuit isnt too bad, exept you have to be able to sense the loading of the motor, as it changes whether its in motion or stopped. too difficult to justify.
the power window kits RETAIL for $60 one way. so thats the better deal, in the end.
$60 plus tax, and wire it up to yrou existing switch, and whenever you pulse it, itll open fully.
this is liek teh third time ive lost a post, im rather dissapointed with the new forum layout....
Old May 9, 2003
  #41
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
you guys are too funny. over thinking.
http://www.autoloc.com/detail.lasso?itemid=WC1000
i have 2 of these for my door windows.
Old May 9, 2003
  #42
XTREME2K2CIVIC's Avatar
Reppin Stage 7
So you think that will work for the sunroof.???
Old May 9, 2003
  #43
jiggerachi's Avatar
Zoom zoom
jiggerachi will become famous soon enough
Owned!!
Old May 9, 2003
  #44
ak's Avatar
ak
Retired Mod
ak can only hope to improve
LOL Derek....hahahaha
Old May 9, 2003
  #45
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
Originally posted by bublik
plus it looks more classy and stylish if someone is in the car, you just hit a button and walah, its opening. THat is why I love pulling up and using the auto window down.
I Have no self esteem
Yea, auto down is cool. but auto-up is the one of the coolest things on my car. Everytime i show someone that it really does work, i get that "O" face lookin back at how my windoes are rolling themselves up with my hands off the switch. Also have that cool auto-roll down feature where i hold teh unlock button on my remote and the windows will roll down as long as i hold it down. (not to mention the cool door lock / window roll down key thing that VW made famous in those goofy commercials...)
dhuff
Sep 28, 2015 08:35 PM
sccarally
Texas
Sep 27, 2015 03:33 PM
speedlever
Sep 24, 2015 07:18 PM
