VTEC Indicator Light - need help!!!
can a small blue 12 volt bulb work with out the resisitor and without screwing the ecu up? I can hook it up straight to a 12 volt source without it being too bright or blowing out, it also looks really nice when lit.
i just installed everything, took about 15 minutes came out awesome. I'm going to make a small DIY on how to do it for people who need some pictures.
Search and Learn
I actually found a DIY with pics. If you look at all the links on the left under "menu", click DIY. There's one under electronics. If it's not enough the one I did has a lot more pictures so let me know if you think I should still make one.
i just ordered ten 200k potentiometers from allelectronics.com because their minimum purchase was 10, so if anyone needs one i might be able to hook you up for a couple bucks (cost + shipping + a lil extra )
PM me or email me at t-r@attbi.com
lol i was reading a webpage that was linked on here and the guy was talking about how the VTEC light isn't just "rice", and I came up with a ricey idea...
while the vtec light by itself may not be "rice", what if you hooked up one of those LED exhaust tips to it so it turned on when VTEC engaged...after burners !!!
now that would be rice
(you could probably do it using a relay so it doesn't draw too much current)
Re: VTEC Indicator Light - need help!!!
We in the philippines have a d16w8 engine on our 2k1 civics we have 3 stage vtec in our engine I tap my wires directly from the engine bay to get this mod to work. tho I have found the green and yellow wire in the ecu box, I hav'nt found the 2nd vtec in the ecu box. Is the some way of me finding that wire? is there a pinout for the ecu of the d16w8? or is it a wierd engine? thanks.
http://www.cardomain.com/ride/2943961/2
i know it's old but I don't have any other sources to understand my engine more since it's a little of unordinary not like the d17's that you guys have in the U.S. but i know it's a dead thread, just checking on it. thanks man
EFCivic1989
Jun 5, 2015 01:12 PM
jimmyfloyd
May 20, 2015 07:06 PM
tylerginevan
Apr 27, 2015 12:29 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
