Halo Projector, wireing needed? Dont see any off the Halo
Old Apr 7, 2003
NukeSilo's Avatar
NukeSilo is an unknown quantity at this point
Question Halo Projector, wireing needed? Dont see any off the Halo
I just got Halo Projectors and looked at the back or the units, There are 2 lights included, 1 towards the middle and 1 in the ion lens, also the led in the halo. There are 2 sockets open, what bulbs go in these? Also there is a total of 6 wires comming off of it, 4 from the light towards the middle = a red, a white which are both bare and a red and a black that got to a three prong connector Then theres 2 commng from the ion that are blue and black that go to the same three prong connector. What do i do with the three prong connector and the red and white wires? Also is the LED Halo wired to those red and black wires from the ion cause i dont see any more wires!? Thanks
Old Apr 7, 2003
blue03civic's Avatar
Pro Skater
yo i was thinking about getting those where did u get them from and for how much? also when ur done can u post pics of them i really need opions.
Old Apr 7, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
You hook the 3 prong connector after you disconnect the old 3 prong off the old lights, you hook the other 2 wires up to the parking lights, red goes to red and the other goes to the ground. so when your parking lights are on, the halo is on.
Old Apr 7, 2003
NeonImpact's Avatar
Forum Sponsor
david02 gave you the answer..
but damn, it sounds like i am glad i stuck with TYC's..
Old Apr 8, 2003
orion_squall's Avatar
hi, so your halo light has 3 circle lights
from inner to outer, you have : high beam, projector (low beam) with ring, and signal light? am I right?
how did you map yours to the OEM bulb socket to those 3 lihgts?
and how will the high beam work?? because in the OEM headlight, the H4 bulb represent both hi and low beam and it has only one socket for it.
Old Apr 8, 2003
Macko's Avatar
Macko is an unknown quantity at this point
the setup
{Grill } (DRL, HIGH)(LOW Beams)(Parking and T.Signals)
Old Apr 8, 2003
R3DL1N3's Avatar
the halo burns out im told
Old Apr 8, 2003
Dr5D's Avatar
ok, dosent seem to me that any of these people answerd any of your questions, no offence.
-the two open places you refer to are for the parking light and the turn signal, you can get the bulbs from the lights you are currently using when they are removed
-all the wires coming from the high and low beam go to the 3 prong connector, that connector looks just like the back of an h4 bulb, since the h4 is both a high and low beam, it splits it up accordingly
-the 2 extra wires are for the halo, most people connect those to the parking lights, but that could also be connected to a switch or somthing
now i didnt hook up the halo on mine, too much bad press - but do whatever you want. i hope i answered your questions
Old Apr 9, 2003
thanks Dr5D,
I have not seem the back of a projector headlights yet, but from the front I see there are 3 circles, from inner to outter. Circle 1, projector, circle 2.
so there should have 3 holes at the back. I don't understand how can there only be 2.
so waht bulb goes into the ion (projector lens)? Can we even put bulb in it?
Old Apr 9, 2003
MaddonE's Avatar
MaddonE is an unknown quantity at this point
so do the halos work when you have your low beams on only or what, when are the halos actually on? thinking about getting them but not too sure yet, i've heard a lot of mixed reviews
Old Apr 9, 2003
Dr5D's Avatar
the halos can be on all the time if you hook it up to your parking lights, or a switch maybe. tho i personally would not recomend it.
i think the bulb for the projector and the high beam is a h1, and they can be changed. tho if you go to change them i wish you luck....
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
pincookie1
May 4, 2015 12:22 PM
Myredjonda
Apr 14, 2015 07:00 PM
CivicHX01
Nov 29, 2001 03:48 PM
klam
Nov 16, 2001 03:36 PM
