trunk springs
Old Apr 2, 2003
7gen03's Avatar
7gen03 is an unknown quantity at this point
Exclamation trunk springs
Well i have a quick question. Where could i et some deeper trunk springs to clear my rear speakers. I know about greys strut diy and have all the stuff i need to do but i also was wondering where i could find some deeper trunk springs just as future reference or a back up plane thanks
7gen03
Old Apr 3, 2003
branden's Avatar
branden is an unknown quantity at this point
you can remove the trunk springs but it won't pop or lift a bit when you open it, you can also convert it into gas shocks like in '95 civics and hb's
Old Apr 3, 2003
7gen03's Avatar
ttt
Old Apr 3, 2003
Connie's Avatar
I am going to get my trunk springs and torsion bars taken out and get a hydrolic lift for both arms and have it by hydrolic both ways, opening and closing
Old Apr 3, 2003
RoadRunner's Avatar
anybody know how to do the suicie hood thing. Like can i have some step by step instructions on how to do this.
Old Apr 3, 2003
RoadRunner's Avatar
i meant suicide hood ...... my bad
Old Apr 4, 2003
sexcivic2k1's Avatar
there is a DIY for it on the site, look around
Old Apr 4, 2003
http://www.7thgencivic.com/modules.p...howpage&pid=40
Flip-Flop Trunk Lid Instructions
Materials:
1 - 2" Window Bolt (7 screws included)
2 - 3" Lt Strap Hinges (13 screws included)
Instructions:
1. With trunk open, mark the trunk lid at the top of the stock brackets.
2. Remove your trunk lid by unbolting 4 bolts. Do not remove the stock brackets, only the trunk lid.
3. Attach the flat side of the enclosed hinge to trunk lid below the marked. With the bottom of the hinge facing down.
4. You will have to bend hinge.
5. With help reattach trunk lid to stock brackets using curved hinge. Be sure to pre-drill all holes before mounting new hinge. This hinge will create the fold down effect.
6. Connect enclosed latches about 2 inches from the bottom of the trunk lid. Be sure they are mounted on the inside of the stock brackets.
7. Mark a spot on the stock bracket to drill to allow the latches to latch. Be sure the latch will latch tightly. If it doesn't latch tightly you may have to replace the stock bottom bolts each time you want to fold down you trunk lid.
Old Apr 5, 2003
RoadRunner's Avatar
thanx i'll be sure to try that out, hopefully everything will work out right
Crazygrlinak
Oct 8, 2015 05:06 PM
skeener51
Oct 1, 2015 05:56 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
