For Those with TYC Projectors, Worth Changing Bulbs?
Old Apr 2, 2003
netcbc's Avatar
netcbc is an unknown quantity at this point
Is it worth changing the H1 regular driving bulbs?
NOT the bulbs where the projectors are but the ones that are on during the day, I've seen other peoples and its yellow, is it worth getting aftermarket bulbs?
Since it won't be fully on and it could still be yellow is it worth it?
Old Apr 2, 2003
Voiceofid's Avatar
End Bringer
you have day light driving bulbs for your car? mine doesn't...
i highly recommend change to something else besides the ones come with your tyc. not fake xenon bulbs, but just regular, bulbs, i noticed a slight improve ment of light output after i got new bulbs, and these were 5.99 GE h1 at discount auto
Old Apr 2, 2003
netcbc's Avatar
This is what I mean
Old Apr 2, 2003
netcbc's Avatar
oh wait or is that the high beam only?
Old Apr 2, 2003
Macko's Avatar
Macko is an unknown quantity at this point
i guess it's depending on the harness...i dun got TYC's but i do have the Angel Eye's ones (unplugged my rings).. and i still have DRL working in these headlights they are on the same as my HIGH beams, IMO... since the DRL is running at low wattage.. i dunno it you can even really see the DRL if you get white bulbs...
Old Apr 3, 2003
Voiceofid's Avatar
End Bringer
the thing your arrow is pointing at is my high beam, and only my high beam. i think the high beam bulb is suffice and doesn't need changing
the order of the bulbs as it follows, according to that picture, from left to right
high beam, low beam, top: parking, bottom: turning
Old Apr 3, 2003
netcbc's Avatar
ohh i see, so I guess if you get HID you'll get DRL light on your dash board fo sho
Old Apr 3, 2003
Voiceofid's Avatar
End Bringer
i would recomend disabling the drl, i heard drl kills hids really fast
Old Apr 3, 2003
netcbc's Avatar
disable DRL? my HIDs dont' even have a DRL to disable, its only night time driving light
Old Apr 3, 2003
FALKEN's Avatar
Civicforums Junkie
im confused...
Old Apr 3, 2003
Voiceofid's Avatar
End Bringer
from what i understand, canada civics have day time running lights, which runs on a lower voltage than your normal low beams. if you do not disable the day time running light, it will feed a low voltage into the hid, and some how shorten it's life (or so it said in some article i read)
Old Apr 3, 2003
FALKEN's Avatar
Civicforums Junkie
sounds like a waste of money to install HID on the DRL/HIGH beam housing...
Old Apr 3, 2003
Dr5D's Avatar
if i had drl it would be the first thing i would want removed!!!!!
Old Apr 3, 2003
netcbc's Avatar
oh US doesn't have DRL? Yea my HID doesn't have DRL and most don't unless you pay sorta alot extra to get it....... thanks for your help voiceofid, your the TYC expert
themechanic
Lighting
Feb 2, 2018 09:23 PM
MamaBear2015
Jun 11, 2015 07:33 PM
eorlando1
May 17, 2015 11:16 AM
Importracer
Nov 17, 2001 03:37 AM
wawacito
Nov 5, 2001 03:32 PM
