Gasket work for 40+ horsepower
Old Mar 31, 2003
Reiki's Avatar
Reiki is an unknown quantity at this point
Alright, I got a dilemma, my friend is an amazing mechanic and he told me he could fix up the gasket on my civic... he could make the holes where the fuel injects or i think it was the air that flows into the engine much bigger, by sanding them down. So I was wondering if anyone knew anything about this. Because he is a very reliable resource and knows what he is doing. So what do you all think? it seems like a good idea, he guarantees about 40 horsepower increase if not more, but he says it varies depending on the car.
Old Mar 31, 2003
HondaLuver's Avatar
Its a celebration bitches!
you mean port and polish... i don't know maby a few horses... and raised compression ratio... probly, going to cost money, i would only let a professional do that to my car.. you wont get that much power, maby 10 max... if he is a super genius, probly 15
Old Mar 31, 2003
THEANTIRICEST's Avatar
Premium Member & 1 Millionth Poster!
THEANTIRICEST has disabled reputation
tell him that if u dont get 40 ur want a money
Old Mar 31, 2003
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
it will gain a little, not too much though, a friend of mine has a V6 accord, he did that to his accord, so far, he hasnt dyno yet, but i wouldnt mind have him do it to my car.
Old Mar 31, 2003
S2000man01's Avatar
O RLY
he can increase compressoin by sanding down the head gasket size. but he should be careful on piston to valve clearance. but no you won't get 40hp.
Old Mar 31, 2003
Reiki's Avatar
Well his dad does it as a profession, and I mean i was a little shaky when he said 40, but i suppose it might be possible if you sand the cylinders so they are bigger
Old Apr 1, 2003
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
i'd do anything for 40 horsies more. i'm not even sure if all the boltons + port/polish + chip would get you 40. but i don't really know much about this modification stuff, so i'm just talking out my ****.
Old Apr 1, 2003
S2000man01's Avatar
O RLY
sanding cylinders would make them smaller=less compression= less hp.
find out EXACTLY what they plan to do to get you 40hp, then come back and i'll tell you if it's BS
Old Apr 1, 2003
Wanger's Avatar
Wanger is an unknown quantity at this point
40hp? man the only way i know of to get that gain is to go custom turbo or no2
Old Apr 1, 2003
LuZi0n's Avatar
LuZi0n is an unknown quantity at this point
i believe a few people have done a port and polish....look through member rides and try to find them and see how much power they gained
Old Apr 1, 2003
RiceBuRNeR's Avatar
Turbo Member
I noticed a small, I repeat small increase in response by sanding down the gasket on my header.
The ports on the engine and the HP header are larger than the ports on the metal gasket, so making them the same size will reduce the restriction of the exhaust. On the other hand I may be loosing a little torque.
If anyone else ever raced ATV's then you know what a torque stuffer is. To thoose of you that dont it basicly a reducer thats placed in the primary tube of the head pipe, that helps build low-end torque.
Old Apr 1, 2003
civicdude's Avatar
Wrong Forum, This belongs in Tech Stuff
Old Apr 1, 2003
flotsamm's Avatar
I think maybe your mechanic meant by sanding the cylinders that he was referring to over-boring the size and installing larger pistons, just like a stroker kit. Not sure if this is even possible or how its done with our blocks.
Old Apr 1, 2003
MMILX's Avatar
MMILX is an unknown quantity at this point
hmm, gasket matching? In many cases, the gasket holes are larger than the manifolds, and you can enlarge the manifold holes to match the gasket...
As for 40hp... doubt it. Honda engineers probably got most, if not all the free tricks from the motor to make it efficient.
You might see a few hp here and there by cleaning up the port work. In all honesty, probably not worth the money.
Old Apr 1, 2003
RedDragon333's Avatar
you wont come close to 40+ hp on what you describing. But get all the details on what EXACTALLY they plan to do then come back here and run it by a few of us
Old Apr 1, 2003
thebigjap's Avatar
thebigjap is an unknown quantity at this point
riceburner said something about a "torque stuffer". I wouldn't mind a little low end torque...any thoughts on a DIY?
Old Apr 1, 2003
RoadRunner's Avatar
40hp ??? From what your describing him doin, it sounds like port and polish and you dont get that much of an increase from that. maybe 10 or 15 at the most.
Old Apr 2, 2003
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
10-15 is still an excellent gain IMO. i would go for it.
Old Apr 4, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
Yeah, I would be down for 15 WHP if I get a good deal on the work.
Old Apr 4, 2003
who wouldnt you would crazi if you didnt
Old Apr 5, 2003
dragoon's Avatar
maybe after a new camshaft youll be closer to that 40hp
HondaHomer
May 14, 2015 12:24 PM
pheaton
May 4, 2015 08:26 PM
ORskier
May 3, 2015 12:54 PM
cloudguy
Apr 28, 2015 05:02 AM
MamaBear2015
26
Apr 16, 2015 11:08 PM
