Neuspeed front strut bar
Old Mar 28, 2003
zlander's Avatar
zlander is an unknown quantity at this point
Question Neuspeed front strut bar
I was wondering if yall had the same problem. Strut bar was installed properly, but it makes noise everytime i turn the steering wheel.
what's the best way to fix this?
Thanx
Old Mar 28, 2003
CarbonFly's Avatar
I never had a problem with my Neuspeed strut bar.
Old Mar 28, 2003
pbfoot's Avatar
did you tighten the screws to propper torque? ive never had a problem either...but it might be that its just sitting a bit loose on the struts.
Old Mar 29, 2003
zlander's Avatar
tighten 33 lbs as instructed. I had to force it to fit when i installed it.
Arent you supposed to put one side first and put the other side next? when i did that it didnt fit and messed up my alignment once.
Have any idea?
Old Mar 29, 2003
cdmx's Avatar
no, your supposed to slowly tighten all bolts, like putting a wheel lugs back on
Old Mar 29, 2003
pbfoot's Avatar
i had to jack one side of my car so that the strut was in the right place. if you just forced the bar on there you might not have put it on all the way down, and now its rubbing.
jack one side up, take off the bar and just put it on again. let us know if that works.
Old Mar 29, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
it shouldnt screw with the alignment since the strut shouldnt be moving... even after you remove all three bolts... at All. i agree it might not be down all the way .. hammer that sucka. lol only kidding ... I tap'd my rear upper one down with a screw driver until it went down all the way... I thought it was supposed to fit tight... I thought thats why they work so well?
Old Mar 29, 2003
CarbonFly's Avatar
I didn't feel like jacking my car up to install it so I just took a rubber hammer and one good whack popped it right on.
Old Mar 29, 2003
zlander's Avatar
Since no one had the same problem then I guess I got a defective strut bar? Man.... this is sad..
Thanks anyways...
Old Mar 30, 2003
Fletchman04's Avatar
Fletchman04 is on a distinguished road
check to see if the threads are the same on each side. it might be a pain but its not worth ripping'em off while your driving.
GH04si
Apr 15, 2015 08:13 PM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
andylao
Nov 4, 2001 01:19 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
