can i change my lights w/o removing the hole set again?!?
blingbling member
i need to change this light cuz i turned into greenish!....it look's nasty now!....i got some whites and wanna change...is there any way to change that with out remove the set again?...
if theres no way i can change.... might just stick with the nasty greens!....
Civicforums Junkie
go through the fenderwell (very easy)
look at the wheel and at about 10 o'clock just under the lip of the fender...there is a grommet...use a flat-head to pull it out and then pull the plastic liner out...reach your arm in there and take out the bulb...then replace with new one...
*this is in the manual*
CarStuff
Dec 6, 2020 12:52 PM
doublins
Nov 11, 2001 07:01 PM
