How To Installl M3 Mirrors??
Old Mar 17, 2003
Blckcivic01's Avatar
Blckcivic01 is an unknown quantity at this point
do you half to rip apart your side panels in your doors or can u just popout the lil black triangle thing in the corner of the windows???? if so on the panels how do you do that?
Old Mar 17, 2003
samscivic's Avatar
samscivic is an unknown quantity at this point
remove the panel by the door handle then unscrew, pop off the door handle extra bar things then u should be able to uncrew from that(should be like around 5 screws total i think). unplug ur wires to make it easier. work panel off from the bottom end to the front top (easier this way) then u have door panel off (beware not to scrape ur paint cause i kinda did, but its cool) then pop off black triangle piece unhook stock mirrors , replace with m3's, wire if u know how then put everything back together. BAm there u go! at least this is what i did.
does anyone know a good detailed DIY for wireing the m3's to blinkers cause i tried this and blew my fuse? thanks
Old Mar 17, 2003
Toca's Avatar
Toca is an unknown quantity at this point
Search its all been posted
