Hyperblinkers?
Procedure for Hyper Lights
1. go to www.hyperblinker.com
2. Spend $16 to get mechanism
3. Plug in into your car
4. Go rice around the town.
there are other ways to do it too!!!!
you could get some LED bulbs for your front or back turn signals, ive heard that works.
and i think there is somthing about removing one of the filiments on the front blinker bulb, i dont remember about that tho
Quote
[hr]
...take out your 7443 bulb (front signal) form the headlight assembly through the fenderwell
...look at the bulb leads (connectors)
...there should be 2 on each side of the 'wedge'
...the lead on the right side of each side is the 21W lead
...bend the right lead (21W) on each side down and snip them off with fingernail clippers
...that takes the 21W out of the loop
...now it's a 5W bulb which creates less resistance
...the connectors won't hook-up properly this way though
so you'll need to bend down the 5W leads as you did the 21W and
flip them to the other side right where the 21W would have been
...replace the bulb back into the socket until it 'clicks'
...after you've done both sides
...turn on the 'hazzard' lights to insure that they still work properly
...don't worry...the 'hazzards' will blink as normal since the loop will look at all the bulbs
...turn off the 'hazzards' and then turn the key to the #2 position
...turn on either signal
BAM!! HYPERBLINKER!!
*The only thing that you will lose with this mod is your 'amber' parking light*
I DON'T MIND THIS THOUGH BECAUSE NOW THE BLINKERS (FRONT / REAR)
ONLY COME ON WHEN I ACTUALLY WANT THEM TO SIGNAL
BTW...This is to make them 2X faster
[hr]
[hr]
[hr]
seems like alot of work and effort for 2x, just shell out the 16.00 and be done.. i only had to shell out 8 shipped, neener neer... btw thanks brian (speedracersong)
Civicforums Junkie
Quote
[hr]Originally posted by: HRocket2k2
seems like alot of work and effort for 2x, just shell out the 16.00 and be done...[hr]
how does that seem like a lot of work??
your simply cutting out one of the leads...using the stock bulbs (no cost) and 10min.
Civicforums Junkie
Quote
[hr]Originally posted by: born2xLr8
^that was from an old thread...not sure which one though. I just happened to have the text saved.[hr]
Quote
[hr]
[hr]
[hr]
[hr]
I WROTE THAT
FALKEN
24
Jan 31, 2007 03:23 AM
